Domain check Captcha problem
MajeStik
  • 5 months later...
I've just started to use WHMCS and I'm having this same issue right now...
the issue is, Derfault's template index page never accepts the captcha, it only sends us to domainchecker page with the captcha error and then we try and it works but that's in domainchecker.php and not index.php
Did you found some fix for captcha working from index page?
