another_reality Posted January 13, 2012 Share Posted January 13, 2012 Hello, I have problem with Greek lang but only on the PDF invoices. I have look my database collocation and is "utf8_general_ci". From the WHMCS Admin the charset is UTF8. My database file is encoded with "UTF8 Without boom" from notepad++. When i see my records directly from phpMyAdmin i see this results "ΧÏυσάνθου ΤÏαπεζοÏντος", also every new record that i add from WHMCS, are stored in the above unkown format. I have try everything that is posted on this forum but the problem persist, i am desperate. Thank for your time. 0 Quote Link to comment Share on other sites More sharing options...
Jbro Posted January 13, 2012 Share Posted January 13, 2012 Pdf does not work for me for years and it does not work for you and probably not for any body else. Relax enjoy your life:-) 0 Quote Link to comment Share on other sites More sharing options...
another_reality Posted January 13, 2012 Author Share Posted January 13, 2012 Hey Jbro, thanks for the quick reply! OK lets forget the PDF invoice system, but i don't think to be OK all the records stored on this format "ΧÏυσάνθου ΤÏαπεζοÏντος". Have you the same problem? Thanks mate, i think i will take more easy now until an official solution! 0 Quote Link to comment Share on other sites More sharing options...
zam Posted January 25, 2012 Share Posted January 25, 2012 Hi, in General Settings->Localization you must set the System Charset to iso-8859-7, even though the db is in utf8_general_ci. I cant remember if you have to re-enter the data in order to see it correctly. 0 Quote Link to comment Share on other sites More sharing options...
