info@sitestech.com Posted January 11, 2012 Share Posted January 11, 2012 Help. I can not integrate my joomla 1.7 with WHMCS. Someone please help me with the code that I have to copy and paste. In the header.tpl and footer.tpl. thank you very much 0 Quote Link to comment Share on other sites More sharing options...
Sitepearl Posted January 12, 2012 Share Posted January 12, 2012 Integrating WHMCS with Joomla has never been easy... there are a couple paid addons you can buy for Joomla that will do this for you, but it will pay off better in the long run if you just build the rest of your site around WHMCS if you are not using it for a dedicated support/ordering application. 0 Quote Link to comment Share on other sites More sharing options...
