Add product after customer pays for another product
I would like to automatically add a product into a customer account when he make a payment for a specific product.
I will explain it better,
- I have a product that the customer always sign up using a specific promotion code, which will give him the first month as free.
- On the second month, the billing will generate an invoice for him. After he pays for it, I would like to add into his account a second product using a specific promotion code.
The first product is a cPanel account, and the second product is a SSL product. So I would like to give customer a free SSL after he pays for that first product on the second month.
This can be achieved with the following steps (answer from WHMCS support, so I am looking for a developer that can do this for me).
You would need to use a hook to do something like this.
http://docs.whmcs.com/Hooks:Invoicing#InvoicePaid
http://docs.whmcs.com/API:Internal_API
http://docs.whmcs.com/API:Add_Order
You could use the InvoicePaid hook to check the invoice being paid and query the database (tblinvoiceitems) to see if this is the second invoice for the hosting product. You would then use the API to add an order to the clients account with a specific product and promotion code.
The above pages will assist you in doing that.
Thanks.
Guilherme
