Domain order problem
I have the latest version (Version: 3.1.2) with the patch from last week.
Everything has worked ok in the past so I am sure the product settings are correct.
The problem I am having is with regards products with free domain names included. The domains are not being included as part of the order.
Also when I then try to just add a domain name order it will always end up being £0.00 even though it has a value set to it in the settings.
Any help would be great.
John
There was an issue in the first 2 hours of the patch released at 12pm GMT on 4th June. If you acted as soon as you got the email and use free domains, you should redownload the patch.
Matt
