Schmarvin Posted July 16, 2011 Share Posted July 16, 2011 For some reason, I only have this problem with my cPanel server. When creating an account, it gives any account that WHMCS creates unlimited disk space. I am ALWAYS having to go back at the end of the day and reset the packages in WHM so that all users have the correct amount of space/bandwidth. Anyone else having this problem? 0 Quote Link to comment Share on other sites More sharing options...
Manchester Web Hosting Posted July 17, 2011 Share Posted July 17, 2011 For some reason, I only have this problem with my cPanel server. When creating an account, it gives any account that WHMCS creates unlimited disk space. I am ALWAYS having to go back at the end of the day and reset the packages in WHM so that all users have the correct amount of space/bandwidth. Anyone else having this problem? Check that you are using the right package names for the hosting accounts and that they are configured in WHMC as such. i initially had this issue, turned out that the package names were incorrect! Hope this helps 0 Quote Link to comment Share on other sites More sharing options...
Schmarvin Posted July 26, 2011 Author Share Posted July 26, 2011 Check that you are using the right package names for the hosting accounts and that they are configured in WHMC as such. i initially had this issue, turned out that the package names were incorrect! Hope this helps No, it wasn't that. But it seems the new patch/upgrade of whmcs fixed the problem. And yea, I thought it would be something like package names, but it wasn't. Things seem to be running smoothly now. 0 Quote Link to comment Share on other sites More sharing options...
