john_h Posted July 16, 2011 Share Posted July 16, 2011 I started using WHMCS fairly recently and wanted to get some feedback from experienced users on this issue. Is there a way to configure multiple registrar modules for the same TLD? For example, I currently resell both Resell.biz and ResellOne and one offers more features than others (whois privacy for one). Ideally, what I would like to do is have two separate domain "products" for the same TLD. One should be for normal domain registration and another for domain registration with whois privacy with an arbitrary extra cost. Is there a way to set up WHMCS this way? Thanks in advance! John 0 Quote Link to comment Share on other sites More sharing options...
othellotech Posted July 16, 2011 Share Posted July 16, 2011 You can handle it manually "out of the box" buy disabling automated registrations, and selecting the registrar you want for that specific domain at order acceptance. Or you can automate it, with a post-checkout hook, to set the registrar on the tbldomains record based on whatever settings you want to check. 0 Quote Link to comment Share on other sites More sharing options...
john_h Posted July 17, 2011 Author Share Posted July 17, 2011 Great information. I will most likely go with the manual option for now and look into the dev docs on implementing a hook. Thanks Rob! 0 Quote Link to comment Share on other sites More sharing options...
