mira99 Posted July 9, 2011 Share Posted July 9, 2011 I update system to 4.5.2 and module registrar Stargate down.... Registrar Error CURL Error: 7 - couldn't connect to host all domains error my ip - registered and working fine. i replace file stargate.php old version - worked fine! that it? so will it be now? files of different versions? 0 Quote Link to comment Share on other sites More sharing options...
ultranet Posted August 14, 2011 Share Posted August 14, 2011 The same to happened to our installation, followed your solution to make this work. Anybody else with the same problem? Any hints from WHMCS Staff? 0 Quote Link to comment Share on other sites More sharing options...
twhiting9275 Posted August 20, 2011 Share Posted August 20, 2011 Confirmed, same here! 0 Quote Link to comment Share on other sites More sharing options...
twhiting9275 Posted August 20, 2011 Share Posted August 20, 2011 Just a followup to those that might be having this issue as well: Apparently, WHMCS is not using the ip it's bound to when connecting to Stargate/resellerclub. You need to add the server's base IP address to your allowed IP's. This resolved this for me, ymmv 0 Quote Link to comment Share on other sites More sharing options...
