stephenM Posted June 18, 2011 Share Posted June 18, 2011 Hi guys, I'm new to WHMCS and thought everything was working, but I've noticed that although invoices are generated correctly and only up to the current month, the "Next Due Date" on the product remains unchanged. To test this I created a fake product and set the "Next Due Date" to 01/04/2011, and then generated invoices. It correctly generated 3 invoices (April, May, June), and refused to generate any more than that, but the "Next Due Date" remained at 01/04/2011. Am I missing something here? It's clearly keeping track of the invoicing history somewhere, but the "Next Due Date" still isn't correct. Thanks 0 Quote Link to comment Share on other sites More sharing options...
MrBen Posted August 22, 2011 Share Posted August 22, 2011 Hi guys, I'm new to WHMCS and thought everything was working, but I've noticed that although invoices are generated correctly and only up to the current month, the "Next Due Date" on the product remains unchanged. To test this I created a fake product and set the "Next Due Date" to 01/04/2011, and then generated invoices. It correctly generated 3 invoices (April, May, June), and refused to generate any more than that, but the "Next Due Date" remained at 01/04/2011. Am I missing something here? It's clearly keeping track of the invoicing history somewhere, but the "Next Due Date" still isn't correct. Thanks Hi! The only thing I figured in regards to this is that once the invoice is paid, the due date changes to the latest unpaid date. So if you pay the equivalent of the invoices that cover your April and May invoices, you will have a due date 01/06/2011. Hope this helps you out. Regards,, Ben 0 Quote Link to comment Share on other sites More sharing options...
othellotech Posted August 23, 2011 Share Posted August 23, 2011 It's clearly keeping track of the invoicing history somewhere, but the "Next Due Date" still isn't correct. Next *due* date only changes after payment for that invoice is received Next *invoice* date moves onwards each time 0 Quote Link to comment Share on other sites More sharing options...
