Ablius Posted May 17, 2011 Share Posted May 17, 2011 Hello everyone. I have a problem I do not understand. The site and installed and operated. But I have problems with crontab me error: php-q / var / www / mysite / htdocs / dbconnect.php Error this </ b> Requires the ionCube PHP Loader to be installed by the ioncube_loader_lin_5.3.so site I tried to sostiure with: lynx-dump / var / www / mysite / htdocs / dbconnect.php but the data does not sync .. any ideas 0 Quote Link to comment Share on other sites More sharing options...
easyhosting Posted May 17, 2011 Share Posted May 17, 2011 Hi well this "Requires the ionCube PHP Loader to be installed by the ioncube_loader_lin_5.3.so site" gives a major clue of what you need to do. if you have root and ssh access then install this from http://www.ioncube.com/loaders.php otherwise ask your host to install this if you don't have root access 0 Quote Link to comment Share on other sites More sharing options...
Ablius Posted May 19, 2011 Author Share Posted May 19, 2011 thanks i solved as advised. thank you very much 0 Quote Link to comment Share on other sites More sharing options...
