  • 0
Problem configuring resell.biz or similar registrar
mathewparet
Question
I tried configuring resell.biz using stargate. I was trying out the demo mode, but it always errors. When I try to submit the registration from my WHMCS Admin Panel, I get the following error:
Action Status - null : Parameter value policy error
Any idea why we have this error?
10 answers to this question
  • 0
simple, look at what you wrote for nameservers.
nameservers should be NS(number).domain
  • 0
That is my hosting namesever. Also there a nameserver always neednot start with ns(number).domain. It can be anything like somename.domain.tld. Only thing is, it should have type A entries pointing to the name server and also should be registered as a nameserver at the domain registrar.
The nameservers I have specified IS valid. If the name server was not valid, WHMCS would give an error like:
Domain Registration Error - NameServer somename.domain.tld is not a valid Nameserver
  • 0
I dont think thats the reason. See I have successfully pointed my domain name at scorpio1.hostrightnow.com
Check attachment
So that would mean a nameserver neednot always be ns1.*
Also I found that this issue with only stargate/resell.biz
I tried to register another domain name under "internetbs" thourgh whmcs with scorpio1.hostrightnow.com as the nameserver an it was SUCCESS.
So its not issue with the nameserver, its issue with the stargate module
  • 0
Hello mathewparet,
This is not caused by the nameserver issue as claimed by the other member. While your nameserver configuration will likely confuse some of your customers, you are correct and it will function.
The cause of the error was almost certainly a miscellaneous error from the registrar, which LogicBoxes or WHMCS cannot intemperate. Most likely the domain you are attempting to register is on a reserved list. As such it would still show-up as available in most WHOIS searches, but when you attempt to register it, you get the error in question.
Edited by Rhyzio
Corrected spelling error
  • 0
ResellerClub shouldn't be functional fully I think because of the HTTP/SOAP URL is different for RESELL.BIZ and ResellerClub. I think is wasn't hard for me to develop a plugin for RESELL.BIZ if the codes of ResellerClub module wasn't encrypted. I already wrote a RESELL.BIZ Registrar module for AccountLab Plus. Please release a registrar plugin for RESELL.BIZ officially for us.
Thanks.
  • 0
I am new in this
I am testing just to learn on Accountlab Plus
Please Can you share rezell.biz module for accountlab plus
Thanks
Answer this question...
