smileys Posted May 8, 2007 Share Posted May 8, 2007 Hi I just got the trial script yesterday and downloaded V3.1.2 I started to install it today and it states in the readmefile and now on the screen that I have to chmod templates_c to 777 I can not find that folder in my download? Am I missing something here? Thank You Laura 0 Quote Link to comment Share on other sites More sharing options...
nitro Posted May 8, 2007 Share Posted May 8, 2007 Hi, that's strange - it should be in there, in the whmcs directory. It's definitely in the installation zip file. Are you sure that you downloaded the "Full Version" zip and not the "Changed Files" one? You could try creating the folder manually and assigning the needed permissions, however I'd be concerned that you might have other files missing. If you continue having problems you might want to check with WHMCS about their installation / configuration services to get you set up. 0 Quote Link to comment Share on other sites More sharing options...
3cellhosting Posted May 8, 2007 Share Posted May 8, 2007 I had the same problem. The folder is in the full install but for some reason my ftp (SmartFtp) did not create the empty folder. I created a folder called templates_c and chmod 777 and all was fine. That was the solution for me - it may work for you too. :wink: Cheers David 0 Quote Link to comment Share on other sites More sharing options...
smileys Posted May 8, 2007 Author Share Posted May 8, 2007 Thank you for your quick responses and suggestions. I did create a blank folder called templates_c and chmodded it to 777 It is installed and working Great!! Again, Thanks Laura Miller 0 Quote Link to comment Share on other sites More sharing options...
