Template issue and download problem
opso
Hello
I have a serious problem with the current template (both portal and default). When I arrive to cart.php?a=checkout everything moves to the left.
What I did so far:
  • Deleted all modifications I made on the template and uploaded the original ones;
  • Overwritten language file;
  • Cleared the template cache;
  • Used both portal template and basic one (out of the box);
I am attaching the screenshots.
I contacted the support on 28/02, provided the FTP details, but no luck so far.
Moreover I have an issue with downloads from the user's area (dl.php). They appear to be extremelly slow. Does someone have the same problem?
Thanks, Giuseppe
