sbenzies Posted January 20, 2011 Share Posted January 20, 2011 I have integrated the AJAX Order Form into my site and it works perfectly using "http://". However, if I use "https://" it displays the form but when you select the product group it does nothing. My SSL is installed and working without errors or warnings on other parts of my site using the same headers as the ajax order form. On the order form page the browser comes up with an SSL warning of "unauthenticated content". What source is the unauthenticated content? How can I fix this? Why isn't the AJAX functionality working with the SSL? Example: https://www.cascadiahosting.com/order.php 0 Quote Link to comment Share on other sites More sharing options...
WebsiteIntegrations Posted January 21, 2011 Share Posted January 21, 2011 works for me (in FF and IE) 0 Quote Link to comment Share on other sites More sharing options...
wildfire Posted March 11, 2011 Share Posted March 11, 2011 I'm having the same exact issue. I'm testing with Firefox and Safari: You can checkout the page here: https://www.wildfirestudio.com/client/order/?pid=1&skip=1 Remove the https and everything works fine. 0 Quote Link to comment Share on other sites More sharing options...
