Need help with Smarty/Foreach/Free domains
What with template systems in general, and smarty in particular, being a PITA to work with, I'm having an "interesting" time with adjusting step two of the orderform regarding free domains.
Despite coding the $freedomaintlds section to be in a fixed width table, the list of TLDs is about 55 screens wide, not 400 pixels ...
{if $freedomaintlds}
<table width="400" align="center" border="1">
<tr><th>* [i]{$LANG.orderfreedomainregistration} {$LANG.orderfreedomainappliesto}: [/i]</th></tr>
<tr><td>[i]{$freedomaintlds}[/i]</td></tr>
</table>
{/if}
Is ignoring the table width and making it 100% of the required width for the content - one day someone will invent a computer that actualy does what its bloody-well-told-to-do !
Anyway, what I actually want is to control how many tlds on each line, or to check if every tld is there and output a different message etc.
So in *theory* ...
{$freetlds = explode(",", $freedomaintlds)}
{foreach $freetlds as $freetld}
$freetld -
{/foreach}
should output each of the tlds one at a time with " - " between them - which would be a start. Sadly no output at all.
Its the foreach it cant cope with, and I've been staring at it way too long to be able to spot wood-from-trees and see the error, so any pointers much appreciated
  • 1 year later...
with many thanks to Matt @ WHMCS ...
* <em>{$LANG.orderfreedomainregistration} {$LANG.orderfreedomainappliesto}</em>
<table>
<tr>
{php}
$freedomaintlds = $this->_tpl_vars["freedomaintlds"];
$freedomaintlds = explode(",",$freedomaintlds);
$freedomaintldsbreakat = 13;
foreach($freedomaintlds as $key=>$value)
       if ($freedomaintldscounter % $freedomaintldsbreakat  == 0)
               echo "</tr><tr>";
       $freedomaintldscounter++;
       echo "<td>$value</td>";
{/php}
</tr>
</table>
{/if}
displays them neatly in a table 13 cells wide - adjust to suit
goes in steptwo and configureproducdomain - just look for the freedomaintlds part :D
