jquery tools problem
pol2005
Hi i designed a layout for whmcs but i have a problem.I've included a jquery tabs animation but it's not working.
Here is my header.tpl :
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="content-type" content="text/html; charset={$charset}" />
<title>{$companyname} - {$pagetitle}{if $kbarticle.title} - {$kbarticle.title}{/if}</title>
{if $systemurl}<base href="{$systemurl}" />
{/if}<link rel="stylesheet" type="text/css" href="templates/{$template}/style.css" />
<script type="text/javascript" src="includes/jscript/jquery.js"></script>
<script type="text/javascript" src="http://cdn.jquerytools.org/1.2.5/jquery.tools.min.js"></script>
{if $livehelpjs}{$livehelpjs}
{/if}
</head>
<body>
<div class="default" id="wrapper">
<div class="header">
<div class="logo">
<ul id="nav-primary">
<li><a href="http://www.easyspace.gr">Home</a></li>
<li><a href="cart.php">Προιόντα</a></li>
<li><a href="clientarea.php">Περιοχή Πελατών</a></li>
<li><a href="submitticket.php">Νέο Αιτήμα Υποστήριξης</a></li>
<li><a href="supporttickets.php">Αιτήματα Υποστήριξης</a></li>
<li><a href="domainchecker.php">Domains</a></li>
<li><a href="contact.php">Επικοινωνία</a></li>
</ul>
</div>
</div><!-- end header -->
<div class="header2">
<div class="header2-wrap"></div>
</div> <!-- end header2 -->
The site is easyspace.gr
  • 3 months later...
see google's first result for "smarty manual"
Ah, I have been firmly. but politely told to RTFM for which I thank you squire!
:D
I had completely forgotten WHMCS was Smarty templates and spent far too long searching this forum using the wrong search queries and coming up with nothing.
I will go now and read the manual...
thanks,
Hedley
I have read the docs, followed examples and am still not able to get my Javascript to work correctly.
I am using this js to load Tweets into my footer:
<script type="text/javascript">
		$(document).ready(function() {
			$("#twitter").getTwitter({
				userName: "dedesignandhost",
				loaderText: "Loading tweets..."
	</script>
I have tried wrapping the entire block, including the <script> </script> in {literal} {/literal}, then inside of that, and all over the place.
Currently I have:
{literal}
		{/literal}
	</script>
and the error I get is:
$("#twitter").getTwitter is not a function
(?)()hosting.php (line 29)
noConflict(j=function())jquery.min.js (line 29)
j = function()
inArray()jquery.min.js (line 37)
[break On This Error] loaderText: "Loading tweets..."
This function is working in a normal HTML template and I am at a loss as to why I can't get it to work in my templates.
Is this suitable for this forum or should I take it over the Smarty forum?
Thanks.
