mraztek Posted August 10, 2010 Share Posted August 10, 2010 hi guys im trying to find out how to make the price of a product work properly example Im trying to offer a product for 10 dollars monthly free setup 5 Annually free setup when i setup everything i do it as Recurring payment type! when i go to the order page, i select the annually term and when i do the check out it only shows $5 total, how can i make it show the total for the 12 months that should be 60??? 0 Quote Link to comment Share on other sites More sharing options...
webcoaster Posted August 10, 2010 Share Posted August 10, 2010 You create the product and set it to annual pricing of $60.00 look to your right on the price setup you will see the field your looking for. 0 Quote Link to comment Share on other sites More sharing options...
b.ahmed Posted August 10, 2010 Share Posted August 10, 2010 When you setup your product price then you have to put TOTAL price of the product. WHMCS will automatically break it down if you have enabled enabled "Monthly Breakdown Option" So if you want to offer product for $5 / Month if client buy annual plan then you have to put 5x12: $60 in pricing editor Annual Price field. WHMCS automatically divide the total price with number of months. Understood ? 0 Quote Link to comment Share on other sites More sharing options...
mraztek Posted August 10, 2010 Author Share Posted August 10, 2010 how is this possible? 0 Quote Link to comment Share on other sites More sharing options...
b.ahmed Posted August 10, 2010 Share Posted August 10, 2010 What's wrong with it? 0 Quote Link to comment Share on other sites More sharing options...
mraztek Posted August 10, 2010 Author Share Posted August 10, 2010 i want to make my do the same when u select a 12 month term it automatically shows the correct price for the 12 month no only shows the 7.99 like my does 0 Quote Link to comment Share on other sites More sharing options...
b.ahmed Posted August 10, 2010 Share Posted August 10, 2010 ok then try disabling "Monthly Breakdown Option" then it will display the total price for 12 months. 0 Quote Link to comment Share on other sites More sharing options...
mraztek Posted August 10, 2010 Author Share Posted August 10, 2010 ok then try disabling "Monthly Breakdown Option" then it will display the total price for 12 months. i did already this is my shows as you can see it doesn't show the the total 191.76 just like the other automatically 0 Quote Link to comment Share on other sites More sharing options...
b.ahmed Posted August 10, 2010 Share Posted August 10, 2010 ok can you please post snap shot of your pricing editor of this product from WHMCS Admin area? you must be entering wrong values there. 0 Quote Link to comment Share on other sites More sharing options...
mraztek Posted August 10, 2010 Author Share Posted August 10, 2010 ok can you please post snap shot of your pricing editor of this product from WHMCS Admin area? you must be entering wrong values there. do you understand what im trng to explain? 0 Quote Link to comment Share on other sites More sharing options...
b.ahmed Posted August 10, 2010 Share Posted August 10, 2010 have you read my first reply? When you setup your product price then you have to put TOTAL price of the product. WHMCS will automatically break it down if you have enabled enabled "Monthly Breakdown Option" So if you want to offer product for $5 / Month if client buy annual plan then you have to put 5x12: $60 in pricing editor Annual Price field. WHMCS automatically divide the total price with number of months. Understood ? You have to enter $7.99x12= $95.88 into annual price. Please try it....... Do same thing with Semi-Annual ..... 0 Quote Link to comment Share on other sites More sharing options...
mraztek Posted August 10, 2010 Author Share Posted August 10, 2010 have you read my first reply? You have to enter $7.99x12= $95.88 into annual price. Please try it....... Do same thing with Semi-Annual ..... yes but when i do that and save it , it automatically changes to price and 0 Quote Link to comment Share on other sites More sharing options...
b.ahmed Posted August 10, 2010 Share Posted August 10, 2010 You mean that you put 95.88 and after saving it's automatically changed to $7.99 in WHMCS ADMIN AREA ? 0 Quote Link to comment Share on other sites More sharing options...
mraztek Posted August 10, 2010 Author Share Posted August 10, 2010 my English is pretty bad! i can't really explain but no everything work fine only the price doesn't get multiply when someone selects the 12 month term, if im selling it for example 2 dollars and i put in the fiel of the 12 month the 2 dollars it should multiply 2X12 i believe and give a result of 24dls in the checkout page 0 Quote Link to comment Share on other sites More sharing options...
b.ahmed Posted August 10, 2010 Share Posted August 10, 2010 Oh Don't worry about English......and For the above example you have to put 24 in annual price. Just put 24 and see what happens..... 0 Quote Link to comment Share on other sites More sharing options...
b.ahmed Posted August 10, 2010 Share Posted August 10, 2010 This is pricing table for one of my product which is $3.99 per Month, $3.99 Per Month for Quarterly Plan, $3.49 Per Month For Semi-Annually Plan and $2.99 per Month For Annual Plan. I hope now you have understood 0 Quote Link to comment Share on other sites More sharing options...
othellotech Posted August 11, 2010 Share Posted August 11, 2010 The "problem" is the OP is putting a *monthly equivalent* in the Annual price and needs to put the total-for-a-yeat into the field and resave the product ... 0 Quote Link to comment Share on other sites More sharing options...
b.ahmed Posted August 11, 2010 Share Posted August 11, 2010 The "problem" is the OP is putting a *monthly equivalent* in the Annual price and needs to put the total-for-a-yeat into the field and resave the product ... Lol that's exactly what i'm trying to explain him since my first reply! I think he fixed it 0 Quote Link to comment Share on other sites More sharing options...
