Upgrade problem
Topgun
Have a problem after upgrading to the new version 3.1.0
We uploaded all the files.
And than I ran the upgrade file all went fine and than it asled to upgrade to 3.1.0 and I went and done it and than it said to remove the Install folder which I did and than I ran the order page and now it says as follows.
Database needs upgrading - please upload the install folder
So I put the folder back and now it wants to do a NEW install which I can do.
So how do I correct it now?
Ok I have redone it now 3 times and get the same thing.
You run the order page abnd you get.
Database needs upgrading - please upload the install folder.
The db was updated it said so, and told me to remove the install folder and we did so.
Any one have any ideas out there what we could have done wrong or is it the up grade?
All I have is the db sql file, I did what the instruction said to OVERWRITE ALL the files and we did and this is what we have now nothing.
This is not a good idea , even it is in the instructions.
next time do this.
1.Upload all your files to a new folder , name it whatever you want .
2.upload your modified templates if any
3.upload a copy of config.php to the new folder from the existing clients folder
4.rename your old folder to old_whmcs and rename the new one to where your license is (whmcs).
5.now run the upgrader and you are ready to go.
This way if anything goes wrong , you can always rename the old_whmcs to your original folder and you have a working copy of your billing system.
Hello Matt,
It was the box was not checked for odd reason.
The other problem I don't no what went wrong there.
All looks good now.
Thanks for the backup system I just put on a week ago.
Saved my butt.
