Sodak1d Posted May 4, 2010 Share Posted May 4, 2010 I downloaded the server module media kit from whmcs' website. in the kit is the template.php file and the readme.pdf As directed, i created a folder and named it custom: /modules/servers/custom I renamed template.php to custom.php : /modules/servers/custom/custom.php When I was editing a product, I selected custom for the module. Unfortunately i can no longer edit the product for some reason. I cant even change the module. Check out my attactment to see the screenshot. does anyone know how to fix or what is the problem? 0 Quote Link to comment Share on other sites More sharing options...
sparky Posted May 4, 2010 Share Posted May 4, 2010 in the file that you renamed to module... open it and do a search and replace for the word "template" to "module" the function names need to be changed as well 0 Quote Link to comment Share on other sites More sharing options...
Sodak1d Posted May 4, 2010 Author Share Posted May 4, 2010 Thanks Sparky! Your faster than WHMCS support team and I posted this on the forum about 3 hours after opening a ticket. 0 Quote Link to comment Share on other sites More sharing options...
