Central-Host.co.uk Posted May 1, 2010 Share Posted May 1, 2010 Hello, My WHMCS is stuck in maintenance mode. I cannot access the WHMCS admin panel either - whenever I try I get this error (click here). Does anyone know of a way to stop the maintenance mode via the database or something. Please help. Regards, Paul Reed 0 Quote Link to comment Share on other sites More sharing options...
thehost5968 Posted May 1, 2010 Share Posted May 1, 2010 Your version number in the database and file set that you are using do not match make ether the version number in the D/B table comfig matches or you have only run the upgraded SQL and not run the install upgraded. 0 Quote Link to comment Share on other sites More sharing options...
Central-Host.co.uk Posted May 2, 2010 Author Share Posted May 2, 2010 Thanks for the response. So how can I tell if this is the problem? And what is the best way to resolve it? Regards, Paul Reed 0 Quote Link to comment Share on other sites More sharing options...
othellotech Posted May 2, 2010 Share Posted May 2, 2010 And what is the best way to resolve it? Restore your DB and Files, run the upgrade again. 0 Quote Link to comment Share on other sites More sharing options...
