afcbob Posted April 6, 2010 Share Posted April 6, 2010 Hi am trying to do this for someone http://forum.whmcs.com/showpost.php?p=95262&postcount=6 but they have the web2.0 order form but can't find the coded in this file. I did still try editing the templates/orderforms/default/viewcart.php but did not work and think is is maybe due to the not having the default one in use its web2.0 Who do i get this to work with the web2.0 order form Thanks for any help. 0 Quote Link to comment Share on other sites More sharing options...
afcbob Posted April 7, 2010 Author Share Posted April 7, 2010 Has anyone else had this problem with the web 2.0 order form. 0 Quote Link to comment Share on other sites More sharing options...
afcbob Posted April 7, 2010 Author Share Posted April 7, 2010 Anyone manage to help me out please 0 Quote Link to comment Share on other sites More sharing options...
BAJI26 Posted April 7, 2010 Share Posted April 7, 2010 Make sure you have the right cart selected in your admin. So if you are editing the default cart .tpls, default should be selected in your admin to see the results. 0 Quote Link to comment Share on other sites More sharing options...
m00 Posted April 7, 2010 Share Posted April 7, 2010 Just add the code from the thread to line 387 (/templates/orderforms/web20cart/viewcart.tpl) after: <label for="pgbtn{$num}">{$gateway.name} 0 Quote Link to comment Share on other sites More sharing options...
afcbob Posted April 7, 2010 Author Share Posted April 7, 2010 Thats the problem that code is not there 0 Quote Link to comment Share on other sites More sharing options...
m00 Posted April 7, 2010 Share Posted April 7, 2010 It is in my viewcart.tpl (default WHMCS 4.2.1 files). Can you post yours? 0 Quote Link to comment Share on other sites More sharing options...
afcbob Posted April 7, 2010 Author Share Posted April 7, 2010 Thats the file templates/orderforms/web20cart/viewcart.tpl <link rel="stylesheet" type="text/css" href="templates/orderforms/web20cart/style.css" /> <script type="text/javascript" src="includes/jscript/pwstrength.js"></script> <h2>{$LANG.carttitle}</h2> {literal} <script language="javascript"> function removeItem(type,num) { var response = confirm("{/literal}{$LANG.cartremoveitemconfirm}{literal}"); if (response) { window.location = 'cart.php?a=remove&r='+type+'&i='+num; } } function emptyCart(type,num) { var response = confirm("{/literal}{$LANG.cartemptyconfirm}{literal}"); if (response) { window.location = 'cart.php?a=empty'; } } </script> {/literal} {if $errormessage} <div class="errorbox">{$errormessage}</div> <br /> {/if} {if !$loggedin && $currencies} <form method="post" action="cart.php?a=view"> <p align="right">{$LANG.choosecurrency}: <select name="currency" onchange="submit()">{foreach from=$currencies item=curr} <option value="{$curr.id}"{if $curr.id eq $currency.id} selected{/if}>{$curr.code}</option> {/foreach}</select> <input type="submit" value="{$LANG.go}" /></p> </form> <br /> {/if} <table width="100%" border="0" align="center" cellpadding="10" cellspacing="0" class="data"> <tr> <th width="55%">{$LANG.orderdesc}</th> <th width="45%">{$LANG.orderprice}</th> </tr> {foreach key=num item=product from=$products} <tr class="carttableproduct"> <td><strong><em>{$product.productinfo.groupname}</em> - {$product.productinfo.name}</strong>{if $product.domain} ({$product.domain}){/if}<br /> {if $product.configoptions} {foreach key=confnum item=configoption from=$product.configoptions} » {$configoption.name}: {if $configoption.type eq 1 || $configoption.type eq 2}{$configoption.option}{elseif $configoption.type eq 3}{if $configoption.qty}{$LANG.yes}{else}{$LANG.no}{/if}{elseif $configoption.type eq 4}{$configoption.qty} x {$configoption.option}{/if}<br /> {/foreach} {/if} </td> <td align="center"><strong>{$product.pricingtext}{if $product.proratadate}<br /> ({$LANG.orderprorata} {$product.proratadate}){/if}</strong></td> </tr> {foreach key=addonnum item=addon from=$product.addons} <tr class="carttableproduct"> <td><strong>{$LANG.orderaddon}</strong> - {$addon.name}</td> <td align="center"><strong>{$addon.pricingtext}</strong></td> </tr> {/foreach} <tr class="carttableconfig"> <td><a href="{$smarty.server.PHP_SELF}?a=confproduct&i={$num}" style="color:#009900;">[{$LANG.carteditproductconfig}]</a> <a href="#" onclick="removeItem('p','{$num}');return false" style="color:#cc0000;">[{$LANG.cartremove}]</a></td> <td> </td> </tr> {/foreach} {foreach key=num item=addon from=$addons} <tr class="carttableproduct"> <td><strong>{$addon.name}</strong><br /> {$addon.productname}{if $addon.domainname} - {$addon.domainname}{/if} </td> <td align="center"><strong>{$addon.pricingtext}</td> </tr> <tr class="carttableconfig"> <td><a href="#" onclick="removeItem('a','{$num}');return false" style="color:#cc0000;">[{$LANG.cartremove}]</a></td> <td> </td> </tr> {/foreach} {foreach key=num item=domain from=$domains} <tr class="carttableproduct"> <td><strong>{if $domain.type eq "register"}{$LANG.orderdomainregistration}{else}{$LANG.orderdomaintransfer}{/if}</strong> - {$domain.domain} - {$domain.regperiod} {$LANG.orderyears}<br /> {if $domain.dnsmanagement} » {$LANG.domaindnsmanagement}<br /> {/if} {if $domain.emailforwarding} » {$LANG.domainemailforwarding}<br /> {/if} {if $domain.idprotection} » {$LANG.domainidprotection}<br /> {/if} </td> <td align="center"><strong>{$domain.price}</strong></td> </tr> <tr class="carttableconfig"> <td><a href="{$smarty.server.PHP_SELF}?a=confdomains" style="color:#009900;">[{$LANG.cartconfigdomainextras}]</a> <a href="#" onclick="removeItem('d','{$num}');return false" style="color:#cc0000;">[{$LANG.cartremove}]</a></td> <td> </td> </tr> {/foreach} {if $cartitems==0} <tr class="clientareatableactive"> <td colspan="2"><br /> {$LANG.cartempty} <br /> <br /></td> </tr> {/if} <tr class="carttablesummary"> <td align="right">{$LANG.ordersubtotal}: </td> <td align="center">{$subtotal}</td> </tr> {if $promotioncode} <tr class="carttablepromotion"> <td align="right">{$promotiondescription}: </td> <td align="center">{$discount}</td> </tr> {/if} {if $taxrate} <tr class="carttablesummary"> <td align="right">{$taxname} @ {$taxrate}%: </td> <td align="center">{$taxtotal}</td> </tr> {/if} {if $taxrate2} <tr class="carttablesummary"> <td align="right">{$taxname2} @ {$taxrate2}%: </td> <td align="center">{$taxtotal2}</td> </tr> {/if} <tr class="carttabledue"> <td align="right">{$LANG.ordertotalduetoday}: </td> <td align="center">{$total}</td> </tr> {if $totalrecurringmonthly || $totalrecurringquarterly || $totalrecurringsemiannually || $totalrecurringannually || $totalrecurringbiennially} <tr class="carttablerecurring"> <td align="right">{$LANG.ordertotalrecurring}: </td> <td align="center">{if $totalrecurringmonthly}{$totalrecurringmonthly} {$LANG.orderpaymenttermmonthly}<br /> {/if} {if $totalrecurringquarterly}{$totalrecurringquarterly} {$LANG.orderpaymenttermquarterly}<br /> {/if} {if $totalrecurringsemiannually}{$totalrecurringsemiannually} {$LANG.orderpaymenttermsemiannually}<br /> {/if} {if $totalrecurringannually}{$totalrecurringannually} {$LANG.orderpaymenttermannually}<br /> {/if} {if $totalrecurringbiennially}{$totalrecurringbiennially} {$LANG.orderpaymenttermbiennially}<br /> {/if}</td> </tr> {/if} </table> <br /> {if !$checkout} <table width="100%" border="0" cellpadding="10" cellspacing="0"> <tr> <td width="55%" align="center"><form method="post" action="{$smarty.server.PHP_SELF}?a=view"> <input type="hidden" name="validatepromo" value="true" /> <strong>{$LANG.orderpromotioncode}</strong> {if $promotioncode}{$promotioncode} - {$promotiondescription}<br /><a href="{$smarty.server.PHP_SELF}?a=removepromo">{$LANG.orderdontusepromo}</a>{else} <input type="text" name="promocode" size="20" /> <input type="submit" value="{$LANG.orderpromovalidatebutton}" /> {/if} </form></td> <td width="45%" align="center"><input type="button" value="{$LANG.emptycart}" onclick="emptyCart();return false" /> <input type="button" value="{$LANG.continueshopping}" onclick="window.location='cart.php'" /> <input type="button" value="{$LANG.checkout}" onclick="window.location='cart.php?a=checkout'"{if $cartitems==0} disabled{/if} /></td> </tr> </table> {else} <form method="post" action="{$smarty.server.PHP_SELF}?a=checkout"> <input type="hidden" name="submit" value="true" /> <h3>{$LANG.yourdetails}</h3> <p>{if !$loggedin}<strong>{$LANG.alreadyregistered}</strong> <a href="{$smarty.server.PHP_SELF}?a=login">{$LANG.clickheretologin}</a>{/if}</p> <table width="100%" border="0" cellpadding="0" cellspacing="0" class="frame"> <tr> <td width="50%" valign="top"><table width="100%" border="0" cellpadding="10" cellspacing="0"> <tr> <td width="100" class="fieldarea">{$LANG.clientareafirstname}</td> <td>{if $loggedin}{$clientsdetails.firstname}{else} <input type="text" name="firstname" style="width:80%;" value="{$clientsdetails.firstname}" /> {/if}</td> </tr> <tr> <td class="fieldarea">{$LANG.clientarealastname}</td> <td>{if $loggedin}{$clientsdetails.lastname}{else} <input type="text" name="lastname" style="width:80%;" value="{$clientsdetails.lastname}" /> {/if}</td> </tr> <tr> <td class="fieldarea">{$LANG.clientareacompanyname}</td> <td>{if $loggedin}{$clientsdetails.companyname}{else} <input type="text" name="companyname" style="width:80%;" value="{$clientsdetails.companyname}" /> {/if}</td> </tr> <tr> <td class="fieldarea"{if !$loggedin} style="height:21px;"{/if}> </td> <td> </td> </tr> <tr> <td class="fieldarea">{$LANG.clientareaemail}</td> <td>{if $loggedin}{$clientsdetails.email}{else} <input type="text" name="email" style="width:90%;" value="{$clientsdetails.email}" /> {/if}</td> </tr> {if $loggedin} <tr> <td class="fieldarea"> </td> <td> </td> </tr> <tr> <td class="fieldarea"> </td> <td> </td> </tr> {else} <tr> <td class="fieldarea">{$LANG.clientareapassword}</td> <td><input type="password" name="password" size="20" id="newpw" /></td> </tr> <tr> <td class="fieldarea">{$LANG.clientareaconfirmpassword}</td> <td><input type="password" name="password2" size="20" /></td> </tr> {/if} </table></td> <td width="50%" valign="top"><table width="100%" border="0" cellpadding="10" cellspacing="0"> <tr> <td width="100" class="fieldarea">{$LANG.clientareaaddress1}</td> <td>{if $loggedin}{$clientsdetails.address1}{else} <input type="text" name="address1" style="width:80%;" value="{$clientsdetails.address1}" /> {/if}</td> </tr> <tr> <td class="fieldarea">{$LANG.clientareaaddress2}</td> <td>{if $loggedin}{$clientsdetails.address2}{else} <input type="text" name="address2" style="width:80%;" value="{$clientsdetails.address2}" /> {/if}</td> </tr> <tr> <td class="fieldarea">{$LANG.clientareacity}</td> <td>{if $loggedin}{$clientsdetails.city}{else} <input type="text" name="city" style="width:80%;" value="{$clientsdetails.city}" /> {/if}</td> </tr> <tr> <td class="fieldarea">{$LANG.clientareastate}</td> <td>{if $loggedin}{$clientsdetails.state}{else} <input type="text" name="state" style="width:80%;" value="{$clientsdetails.state}" /> {/if}</td> </tr> <tr> <td class="fieldarea">{$LANG.clientareapostcode}</td> <td>{if $loggedin}{$clientsdetails.postcode}{else} <input type="text" name="postcode" size="15" value="{$clientsdetails.postcode}" /> {/if}</td> </tr> <tr> <td class="fieldarea">{$LANG.clientareacountry}</td> <td>{if $loggedin}{$clientsdetails.country}{else}{$clientcountrydropdown}{/if}</td> </tr> <tr> <td class="fieldarea">{$LANG.clientareaphonenumber}</td> <td>{if $loggedin}{$clientsdetails.phonenumber}{else} <input type="text" name="phonenumber" size="20" value="{$clientsdetails.phonenumber}" /> {/if}</td> </tr> </table></td> </tr> </table> {if !$loggedin}<script language="javascript">showStrengthBar();</script>{/if} {if $customfields || $securityquestions} <br /> <table width="100%" cellspacing="1" cellpadding="0" class="frame"> <tr> <td><table width="100%" cellpadding="2"> {if $securityquestions && !$loggedin} <tr><td width="200" class="fieldarea">{$LANG.clientareasecurityquestion}</td><td><select name="securityqid"> {foreach key=num item=question from=$securityquestions} <option value={$question.id}>{$question.question}</option> {/foreach} </select></td></tr> <tr> <td class="fieldarea">{$LANG.clientareasecurityanswer}</td><td><input type="password" name="securityqans" size="30"></td> </tr> {/if} {foreach key=num item=customfield from=$customfields} <tr><td width="200" class="fieldarea">{$customfield.name}</td><td>{$customfield.input} {$customfield.description}</td></tr> {/foreach} </table></td> </tr> </table> {/if} {if $taxenabled && !$loggedin} <p align="center">{$LANG.carttaxupdateselections} <input type="submit" value="{$LANG.carttaxupdateselectionsupdate}" name="updateonly" /> </p> {/if} {if $domainsinorder} <h3>{$LANG.domainregistrantinfo}</h3> {if $addcontact} <input type="hidden" name="contact" value="addingnew" /> <table width="100%" cellspacing="0" cellpadding="0" class="frame"> <tr> <td width="50%" valign="top"><table width="100%" border="0" cellpadding="10" cellspacing="0"> <tr> <td width="100" class="fieldarea">{$LANG.clientareafirstname}</td> <td><input type="text" name="domaincontactfirstname" style="width:80%;" value="{$domaincontact.firstname}" /></td> </tr> <tr> <td class="fieldarea">{$LANG.clientarealastname}</td> <td><input type="text" name="domaincontactlastname" style="width:80%;" value="{$domaincontact.lastname}" /></td> </tr> <tr> <td class="fieldarea">{$LANG.clientareacompanyname}</td> <td><input type="text" name="domaincontactcompanyname" style="width:80%;" value="{$domaincontact.companyname}" /></td> </tr> <tr> <td class="fieldarea" style="height:21px;"><br /></td> <td></td> </tr> <tr> <td class="fieldarea">{$LANG.clientareaemail}</td> <td><input type="text" name="domaincontactemail" style="width:90%;" value="{$domaincontact.email}" /></td> </tr> <tr> <td class="fieldarea">{$LANG.clientareaphonenumber}</td> <td><input type="text" name="domaincontactphonenumber" size="20" value="{$domaincontact.phonenumber}" /></td> </tr> </table></td> <td width="50%" valign="top"><table width="100%" border="0" cellpadding="10" cellspacing="0"> <tr> <td width="100" class="fieldarea">{$LANG.clientareaaddress1}</td> <td><input type="text" name="domaincontactaddress1" style="width:80%;" value="{$domaincontact.address1}" /></td> </tr> <tr> <td class="fieldarea">{$LANG.clientareaaddress2}</td> <td><input type="text" name="domaincontactaddress2" style="width:80%;" value="{$domaincontact.address2}" /></td> </tr> <tr> <td class="fieldarea">{$LANG.clientareacity}</td> <td><input type="text" name="domaincontactcity" style="width:80%;" value="{$domaincontact.city}" /></td> </tr> <tr> <td class="fieldarea">{$LANG.clientareastate}</td> <td><input type="text" name="domaincontactstate" style="width:80%;" value="{$domaincontact.state}" /></td> </tr> <tr> <td class="fieldarea">{$LANG.clientareapostcode}</td> <td><input type="text" name="domaincontactpostcode" size="15" value="{$domaincontact.postcode}" /></td> </tr> <tr> <td class="fieldarea">{$LANG.clientareacountry}</td> <td>{$domaincontactcountrydropdown}</td> </tr> </table></td> </tr> </table> {else} <p>{$LANG.domainregistrantchoose}: <select name="contact"> <option value="">{$LANG.usedefaultcontact}</option> {foreach key=num item=domaincontact from=$domaincontacts} <option value="{$domaincontact.id}">{$domaincontact.name}</option> {/foreach} <option value="new">{$LANG.clientareanavaddcontact}...</option> </select> <br /> </p> {/if} {/if} <h3>{$LANG.orderpaymentmethod}</h3> <p align="center">{foreach key=num item=gateway from=$gateways} <input type="radio" name="paymentmethod" value="{$gateway.sysname}" id="pgbtn{$num}"{if $selectedgateway eq $gateway.sysname} checked{/if} /> <label for="pgbtn{$num}">{$gateway.name}</label> {/foreach}</p> {if $shownotesfield} <h3>{$LANG.ordernotes}</h3> <p align="center"> <textarea name="notes" rows="4" cols="100" onFocus="if(this.value=='{$LANG.ordernotesdescription}'){ldelim}this.value='';{rdelim}" onBlur="if (this.value==''){ldelim}this.value='{$LANG.ordernotesdescription}';{rdelim}">{$notes}</textarea> </p> {/if} <p align="center">{if $paymentmethod eq "2Checkout - Credit Card"} 2Checkout.com, Inc. is an authorized retailer of goods and services provided by {$companyname}.{/if}</p> {if $accepttos} <p align="center"> <input type="checkbox" name="accepttos" id="accepttos" /> <label for="accepttos">{$LANG.ordertosagreement} <a href="{$tosurl}" target="_blank">{$LANG.ordertos}</a></label> <p> {/if} <p align="center"> <input type="submit" value="{$LANG.completeorder}"{if $cartitems==0} disabled{/if} onclick="this.value='{$LANG.pleasewait}'" /> </p> <p><img src="images/padlock.gif" border="0" class="imgfloat" alt="Secure Transaction" /> {$LANG.ordersecure} (<strong>{$ipaddress}</strong>) {$LANG.ordersecure2}</p> <p align="center">{if $paymentmethod eq "2Checkout - Credit Card"} 2Checkout.com, Inc. is an authorized retailer of goods and services provided by {$companyname}.{/if}</p> </form> {/if}<br /> 0 Quote Link to comment Share on other sites More sharing options...
m00 Posted April 7, 2010 Share Posted April 7, 2010 In your case, it was on line 365. The full code you need is: <link rel="stylesheet" type="text/css" href="templates/orderforms/web20cart/style.css" /> <script type="text/javascript" src="includes/jscript/pwstrength.js"></script> <h2>{$LANG.carttitle}</h2> {literal} <script language="javascript"> function removeItem(type,num) { var response = confirm("{/literal}{$LANG.cartremoveitemconfirm}{literal}"); if (response) { window.location = 'cart.php?a=remove&r='+type+'&i='+num; } } function emptyCart(type,num) { var response = confirm("{/literal}{$LANG.cartemptyconfirm}{literal}"); if (response) { window.location = 'cart.php?a=empty'; } } </script> {/literal} {if $errormessage} <div class="errorbox">{$errormessage}</div> <br /> {/if} {if !$loggedin && $currencies} <form method="post" action="cart.php?a=view"> <p align="right">{$LANG.choosecurrency}: <select name="currency" onchange="submit()">{foreach from=$currencies item=curr} <option value="{$curr.id}"{if $curr.id eq $currency.id} selected{/if}>{$curr.code}</option> {/foreach}</select> <input type="submit" value="{$LANG.go}" /></p> </form> <br /> {/if} <table width="100%" border="0" align="center" cellpadding="10" cellspacing="0" class="data"> <tr> <th width="55%">{$LANG.orderdesc}</th> <th width="45%">{$LANG.orderprice}</th> </tr> {foreach key=num item=product from=$products} <tr class="carttableproduct"> <td><strong><em>{$product.productinfo.groupname}</em> - {$product.productinfo.name}</strong>{if $product.domain} ({$product.domain}){/if}<br /> {if $product.configoptions} {foreach key=confnum item=configoption from=$product.configoptions} » {$configoption.name}: {if $configoption.type eq 1 || $configoption.type eq 2}{$configoption.option}{elseif $configoption.type eq 3}{if $configoption.qty}{$LANG.yes}{else}{$LANG.no}{/if}{elseif $configoption.type eq 4}{$configoption.qty} x {$configoption.option}{/if}<br /> {/foreach} {/if} </td> <td align="center"><strong>{$product.pricingtext}{if $product.proratadate}<br /> ({$LANG.orderprorata} {$product.proratadate}){/if}</strong></td> </tr> {foreach key=addonnum item=addon from=$product.addons} <tr class="carttableproduct"> <td><strong>{$LANG.orderaddon}</strong> - {$addon.name}</td> <td align="center"><strong>{$addon.pricingtext}</strong></td> </tr> {/foreach} <tr class="carttableconfig"> <td><a href="{$smarty.server.PHP_SELF}?a=confproduct&i={$num}" style="color:#009900;">[{$LANG.carteditproductconfig}]</a> <a href="#" onclick="removeItem('p','{$num}');return false" style="color:#cc0000;">[{$LANG.cartremove}]</a></td> <td> </td> </tr> {/foreach} {foreach key=num item=addon from=$addons} <tr class="carttableproduct"> <td><strong>{$addon.name}</strong><br /> {$addon.productname}{if $addon.domainname} - {$addon.domainname}{/if} </td> <td align="center"><strong>{$addon.pricingtext}</td> </tr> <tr class="carttableconfig"> <td><a href="#" onclick="removeItem('a','{$num}');return false" style="color:#cc0000;">[{$LANG.cartremove}]</a></td> <td> </td> </tr> {/foreach} {foreach key=num item=domain from=$domains} <tr class="carttableproduct"> <td><strong>{if $domain.type eq "register"}{$LANG.orderdomainregistration}{else}{$LANG.orderdomaintransfer}{/if}</strong> - {$domain.domain} - {$domain.regperiod} {$LANG.orderyears}<br /> {if $domain.dnsmanagement} » {$LANG.domaindnsmanagement}<br /> {/if} {if $domain.emailforwarding} » {$LANG.domainemailforwarding}<br /> {/if} {if $domain.idprotection} » {$LANG.domainidprotection}<br /> {/if} </td> <td align="center"><strong>{$domain.price}</strong></td> </tr> <tr class="carttableconfig"> <td><a href="{$smarty.server.PHP_SELF}?a=confdomains" style="color:#009900;">[{$LANG.cartconfigdomainextras}]</a> <a href="#" onclick="removeItem('d','{$num}');return false" style="color:#cc0000;">[{$LANG.cartremove}]</a></td> <td> </td> </tr> {/foreach} {if $cartitems==0} <tr class="clientareatableactive"> <td colspan="2"><br /> {$LANG.cartempty} <br /> <br /></td> </tr> {/if} <tr class="carttablesummary"> <td align="right">{$LANG.ordersubtotal}: </td> <td align="center">{$subtotal}</td> </tr> {if $promotioncode} <tr class="carttablepromotion"> <td align="right">{$promotiondescription}: </td> <td align="center">{$discount}</td> </tr> {/if} {if $taxrate} <tr class="carttablesummary"> <td align="right">{$taxname} @ {$taxrate}%: </td> <td align="center">{$taxtotal}</td> </tr> {/if} {if $taxrate2} <tr class="carttablesummary"> <td align="right">{$taxname2} @ {$taxrate2}%: </td> <td align="center">{$taxtotal2}</td> </tr> {/if} <tr class="carttabledue"> <td align="right">{$LANG.ordertotalduetoday}: </td> <td align="center">{$total}</td> </tr> {if $totalrecurringmonthly || $totalrecurringquarterly || $totalrecurringsemiannually || $totalrecurringannually || $totalrecurringbiennially} <tr class="carttablerecurring"> <td align="right">{$LANG.ordertotalrecurring}: </td> <td align="center">{if $totalrecurringmonthly}{$totalrecurringmonthly} {$LANG.orderpaymenttermmonthly}<br /> {/if} {if $totalrecurringquarterly}{$totalrecurringquarterly} {$LANG.orderpaymenttermquarterly}<br /> {/if} {if $totalrecurringsemiannually}{$totalrecurringsemiannually} {$LANG.orderpaymenttermsemiannually}<br /> {/if} {if $totalrecurringannually}{$totalrecurringannually} {$LANG.orderpaymenttermannually}<br /> {/if} {if $totalrecurringbiennially}{$totalrecurringbiennially} {$LANG.orderpaymenttermbiennially}<br /> {/if}</td> </tr> {/if} </table> <br /> {if !$checkout} <table width="100%" border="0" cellpadding="10" cellspacing="0"> <tr> <td width="55%" align="center"><form method="post" action="{$smarty.server.PHP_SELF}?a=view"> <input type="hidden" name="validatepromo" value="true" /> <strong>{$LANG.orderpromotioncode}</strong> {if $promotioncode}{$promotioncode} - {$promotiondescription}<br /><a href="{$smarty.server.PHP_SELF}?a=removepromo">{$LANG.orderdontusepromo}</a>{else} <input type="text" name="promocode" size="20" /> <input type="submit" value="{$LANG.orderpromovalidatebutton}" /> {/if} </form></td> <td width="45%" align="center"><input type="button" value="{$LANG.emptycart}" onclick="emptyCart();return false" /> <input type="button" value="{$LANG.continueshopping}" onclick="window.location='cart.php'" /> <input type="button" value="{$LANG.checkout}" onclick="window.location='cart.php?a=checkout'"{if $cartitems==0} disabled{/if} /></td> </tr> </table> {else} <form method="post" action="{$smarty.server.PHP_SELF}?a=checkout"> <input type="hidden" name="submit" value="true" /> <h3>{$LANG.yourdetails}</h3> <p>{if !$loggedin}<strong>{$LANG.alreadyregistered}</strong> <a href="{$smarty.server.PHP_SELF}?a=login">{$LANG.clickheretologin}</a>{/if}</p> <table width="100%" border="0" cellpadding="0" cellspacing="0" class="frame"> <tr> <td width="50%" valign="top"><table width="100%" border="0" cellpadding="10" cellspacing="0"> <tr> <td width="100" class="fieldarea">{$LANG.clientareafirstname}</td> <td>{if $loggedin}{$clientsdetails.firstname}{else} <input type="text" name="firstname" style="width:80%;" value="{$clientsdetails.firstname}" /> {/if}</td> </tr> <tr> <td class="fieldarea">{$LANG.clientarealastname}</td> <td>{if $loggedin}{$clientsdetails.lastname}{else} <input type="text" name="lastname" style="width:80%;" value="{$clientsdetails.lastname}" /> {/if}</td> </tr> <tr> <td class="fieldarea">{$LANG.clientareacompanyname}</td> <td>{if $loggedin}{$clientsdetails.companyname}{else} <input type="text" name="companyname" style="width:80%;" value="{$clientsdetails.companyname}" /> {/if}</td> </tr> <tr> <td class="fieldarea"{if !$loggedin} style="height:21px;"{/if}> </td> <td> </td> </tr> <tr> <td class="fieldarea">{$LANG.clientareaemail}</td> <td>{if $loggedin}{$clientsdetails.email}{else} <input type="text" name="email" style="width:90%;" value="{$clientsdetails.email}" /> {/if}</td> </tr> {if $loggedin} <tr> <td class="fieldarea"> </td> <td> </td> </tr> <tr> <td class="fieldarea"> </td> <td> </td> </tr> {else} <tr> <td class="fieldarea">{$LANG.clientareapassword}</td> <td><input type="password" name="password" size="20" id="newpw" /></td> </tr> <tr> <td class="fieldarea">{$LANG.clientareaconfirmpassword}</td> <td><input type="password" name="password2" size="20" /></td> </tr> {/if} </table></td> <td width="50%" valign="top"><table width="100%" border="0" cellpadding="10" cellspacing="0"> <tr> <td width="100" class="fieldarea">{$LANG.clientareaaddress1}</td> <td>{if $loggedin}{$clientsdetails.address1}{else} <input type="text" name="address1" style="width:80%;" value="{$clientsdetails.address1}" /> {/if}</td> </tr> <tr> <td class="fieldarea">{$LANG.clientareaaddress2}</td> <td>{if $loggedin}{$clientsdetails.address2}{else} <input type="text" name="address2" style="width:80%;" value="{$clientsdetails.address2}" /> {/if}</td> </tr> <tr> <td class="fieldarea">{$LANG.clientareacity}</td> <td>{if $loggedin}{$clientsdetails.city}{else} <input type="text" name="city" style="width:80%;" value="{$clientsdetails.city}" /> {/if}</td> </tr> <tr> <td class="fieldarea">{$LANG.clientareastate}</td> <td>{if $loggedin}{$clientsdetails.state}{else} <input type="text" name="state" style="width:80%;" value="{$clientsdetails.state}" /> {/if}</td> </tr> <tr> <td class="fieldarea">{$LANG.clientareapostcode}</td> <td>{if $loggedin}{$clientsdetails.postcode}{else} <input type="text" name="postcode" size="15" value="{$clientsdetails.postcode}" /> {/if}</td> </tr> <tr> <td class="fieldarea">{$LANG.clientareacountry}</td> <td>{if $loggedin}{$clientsdetails.country}{else}{$clientcountrydropdown}{/if}</td> </tr> <tr> <td class="fieldarea">{$LANG.clientareaphonenumber}</td> <td>{if $loggedin}{$clientsdetails.phonenumber}{else} <input type="text" name="phonenumber" size="20" value="{$clientsdetails.phonenumber}" /> {/if}</td> </tr> </table></td> </tr> </table> {if !$loggedin}<script language="javascript">showStrengthBar();</script>{/if} {if $customfields || $securityquestions} <br /> <table width="100%" cellspacing="1" cellpadding="0" class="frame"> <tr> <td><table width="100%" cellpadding="2"> {if $securityquestions && !$loggedin} <tr><td width="200" class="fieldarea">{$LANG.clientareasecurityquestion}</td><td><select name="securityqid"> {foreach key=num item=question from=$securityquestions} <option value={$question.id}>{$question.question}</option> {/foreach} </select></td></tr> <tr> <td class="fieldarea">{$LANG.clientareasecurityanswer}</td><td><input type="password" name="securityqans" size="30"></td> </tr> {/if} {foreach key=num item=customfield from=$customfields} <tr><td width="200" class="fieldarea">{$customfield.name}</td><td>{$customfield.input} {$customfield.description}</td></tr> {/foreach} </table></td> </tr> </table> {/if} {if $taxenabled && !$loggedin} <p align="center">{$LANG.carttaxupdateselections} <input type="submit" value="{$LANG.carttaxupdateselectionsupdate}" name="updateonly" /> </p> {/if} {if $domainsinorder} <h3>{$LANG.domainregistrantinfo}</h3> {if $addcontact} <input type="hidden" name="contact" value="addingnew" /> <table width="100%" cellspacing="0" cellpadding="0" class="frame"> <tr> <td width="50%" valign="top"><table width="100%" border="0" cellpadding="10" cellspacing="0"> <tr> <td width="100" class="fieldarea">{$LANG.clientareafirstname}</td> <td><input type="text" name="domaincontactfirstname" style="width:80%;" value="{$domaincontact.firstname}" /></td> </tr> <tr> <td class="fieldarea">{$LANG.clientarealastname}</td> <td><input type="text" name="domaincontactlastname" style="width:80%;" value="{$domaincontact.lastname}" /></td> </tr> <tr> <td class="fieldarea">{$LANG.clientareacompanyname}</td> <td><input type="text" name="domaincontactcompanyname" style="width:80%;" value="{$domaincontact.companyname}" /></td> </tr> <tr> <td class="fieldarea" style="height:21px;"><br /></td> <td></td> </tr> <tr> <td class="fieldarea">{$LANG.clientareaemail}</td> <td><input type="text" name="domaincontactemail" style="width:90%;" value="{$domaincontact.email}" /></td> </tr> <tr> <td class="fieldarea">{$LANG.clientareaphonenumber}</td> <td><input type="text" name="domaincontactphonenumber" size="20" value="{$domaincontact.phonenumber}" /></td> </tr> </table></td> <td width="50%" valign="top"><table width="100%" border="0" cellpadding="10" cellspacing="0"> <tr> <td width="100" class="fieldarea">{$LANG.clientareaaddress1}</td> <td><input type="text" name="domaincontactaddress1" style="width:80%;" value="{$domaincontact.address1}" /></td> </tr> <tr> <td class="fieldarea">{$LANG.clientareaaddress2}</td> <td><input type="text" name="domaincontactaddress2" style="width:80%;" value="{$domaincontact.address2}" /></td> </tr> <tr> <td class="fieldarea">{$LANG.clientareacity}</td> <td><input type="text" name="domaincontactcity" style="width:80%;" value="{$domaincontact.city}" /></td> </tr> <tr> <td class="fieldarea">{$LANG.clientareastate}</td> <td><input type="text" name="domaincontactstate" style="width:80%;" value="{$domaincontact.state}" /></td> </tr> <tr> <td class="fieldarea">{$LANG.clientareapostcode}</td> <td><input type="text" name="domaincontactpostcode" size="15" value="{$domaincontact.postcode}" /></td> </tr> <tr> <td class="fieldarea">{$LANG.clientareacountry}</td> <td>{$domaincontactcountrydropdown}</td> </tr> </table></td> </tr> </table> {else} <p>{$LANG.domainregistrantchoose}: <select name="contact"> <option value="">{$LANG.usedefaultcontact}</option> {foreach key=num item=domaincontact from=$domaincontacts} <option value="{$domaincontact.id}">{$domaincontact.name}</option> {/foreach} <option value="new">{$LANG.clientareanavaddcontact}...</option> </select> <br /> </p> {/if} {/if} <h3>{$LANG.orderpaymentmethod}</h3> <p align="center">{foreach key=num item=gateway from=$gateways} <input type="radio" name="paymentmethod" value="{$gateway.sysname}" id="pgbtn{$num}"{if $selectedgateway eq $gateway.sysname} checked{/if} /> <label for="pgbtn{$num}">{$gateway.name}<br />{if $gateway.sysname}<img align="center" src="images/{$gateway.sysname}.gif" />{/if}<br /></label> {/foreach}</p> {if $shownotesfield} <h3>{$LANG.ordernotes}</h3> <p align="center"> <textarea name="notes" rows="4" cols="100" onFocus="if(this.value=='{$LANG.ordernotesdescription}'){ldelim}this.value='';{rdelim}" onBlur="if (this.value==''){ldelim}this.value='{$LANG.ordernotesdescription}';{rdelim}">{$notes}</textarea> </p> {/if} <p align="center">{if $paymentmethod eq "2Checkout - Credit Card"} 2Checkout.com, Inc. is an authorized retailer of goods and services provided by {$companyname}.{/if}</p> {if $accepttos} <p align="center"> <input type="checkbox" name="accepttos" id="accepttos" /> <label for="accepttos">{$LANG.ordertosagreement} <a href="{$tosurl}" target="_blank">{$LANG.ordertos}</a></label> <p> {/if} <p align="center"> <input type="submit" value="{$LANG.completeorder}"{if $cartitems==0} disabled{/if} onclick="this.value='{$LANG.pleasewait}'" /> </p> <p><img src="images/padlock.gif" border="0" class="imgfloat" alt="Secure Transaction" /> {$LANG.ordersecure} (<strong>{$ipaddress}</strong>) {$LANG.ordersecure2}</p> <p align="center">{if $paymentmethod eq "2Checkout - Credit Card"} 2Checkout.com, Inc. is an authorized retailer of goods and services provided by {$companyname}.{/if}</p> </form> {/if}<br /> 0 Quote Link to comment Share on other sites More sharing options...
afcbob Posted April 7, 2010 Author Share Posted April 7, 2010 Thank you so much. 0 Quote Link to comment Share on other sites More sharing options...
afcbob Posted April 8, 2010 Author Share Posted April 8, 2010 One more thing is there away to have it so when you hover over the images text will show ie say the paypal image you hover over it and it will show pay by palpal and so on for each image. 0 Quote Link to comment Share on other sites More sharing options...
BAJI26 Posted April 9, 2010 Share Posted April 9, 2010 Add title="this is the text you want to show" to your <img> tags. 0 Quote Link to comment Share on other sites More sharing options...
afcbob Posted April 9, 2010 Author Share Posted April 9, 2010 How would that work for each image as it only has one image tag that calls the images so every image would have the same text would it not. 0 Quote Link to comment Share on other sites More sharing options...
m00 Posted April 9, 2010 Share Posted April 9, 2010 <img align="center" src="images/{$gateway.sysname}.gif" title="Pay with {$gateway.name}" alt="{$gateway.name}" /> 0 Quote Link to comment Share on other sites More sharing options...
afcbob Posted April 9, 2010 Author Share Posted April 9, 2010 Sorry one last thing thee text before the image can this be removed so its just the image and the hover text. And thanks for all the help to get it sorted. 0 Quote Link to comment Share on other sites More sharing options...
m00 Posted April 9, 2010 Share Posted April 9, 2010 Sorry one last thing thee text before the image can this be removed so its just the image and the hover text. And thanks for all the help to get it sorted. Sure, no problem, just remove the: {$gateway.name}<br /> 0 Quote Link to comment Share on other sites More sharing options...
afcbob Posted April 17, 2010 Author Share Posted April 17, 2010 Is there away to have the hover say custom things ie Major Credit and Debit Cards PayPal Payments - 2Checkout is a Authorized Reseller Thanks 0 Quote Link to comment Share on other sites More sharing options...
Wiredremix Posted April 18, 2010 Share Posted April 18, 2010 We used the if tags to display certain extra text/images. for example {if $gateway.sysname eq "Paypal"}Hello this is paypal{/if} That sort of thing, Which works well on our application. 0 Quote Link to comment Share on other sites More sharing options...
afcbob Posted April 18, 2010 Author Share Posted April 18, 2010 Did not work for me but i must of did it wrong could you show me where i should be putting it so it works and do i need to change any of the code i have. 0 Quote Link to comment Share on other sites More sharing options...
Wiredremix Posted April 18, 2010 Share Posted April 18, 2010 Sorry, the text i placed above was just a example and not the exact code in which to use. This code below works {if $gateway.name eq "PayPal"}This works{/if} You need to make sure the the eq section matches exactly caps/non caps as to how it is displayed. 0 Quote Link to comment Share on other sites More sharing options...
afcbob Posted April 18, 2010 Author Share Posted April 18, 2010 Still does not work the way i need it too i need it to display a image not text the text should only display when you hover. And want each image to have different text when you hover. 0 Quote Link to comment Share on other sites More sharing options...
Wiredremix Posted April 18, 2010 Share Posted April 18, 2010 Well no its not going to work exactly as you have described, you have to write some more custom code. But the above text will help you acheave that. If you are inexperienced in html/css i surgest you hire someone who can do exactly what you are asking as its not too difficult to acheave. 0 Quote Link to comment Share on other sites More sharing options...
m00 Posted April 18, 2010 Share Posted April 18, 2010 Just use the sysname, then it's the same name as you name your images: {if $gateway.sysname eq "paypal"}Major Credit and Debit Cards PayPal Payments{elseif $gateway.sysname eq "tco"}2Checkout is a Authorized Reseller{else}Pay now using {$gateway.name}{/if} 0 Quote Link to comment Share on other sites More sharing options...
afcbob Posted April 18, 2010 Author Share Posted April 18, 2010 Yup that looks like the one 0 Quote Link to comment Share on other sites More sharing options...
