mikenra Posted March 26, 2010 Share Posted March 26, 2010 I know this is probably obvious, but I cant find the packageid for my free trial product. I mouse over the edit icon, as is explained in the Web Hosting Business Book, nothing. Any help would be greatly appreciated 0 Quote Link to comment Share on other sites More sharing options...
sparky Posted March 26, 2010 Share Posted March 26, 2010 while in the edit product from admin click on the "other" tab and look at the bottom for the link 0 Quote Link to comment Share on other sites More sharing options...
mikenra Posted March 26, 2010 Author Share Posted March 26, 2010 while in the edit product from admin click on the "other" tab and look at the bottom for the link Thank you thank you thank you!!! One more quick ? In the removetrial.php file it says to replace 'packageid=16 OR Packageid=17 with your package ID. Well, my trial package is ID 6. Not sure if I change both to packageid=6 or what... Thanks! 0 Quote Link to comment Share on other sites More sharing options...
sparky Posted March 26, 2010 Share Posted March 26, 2010 If you only have 1 then remove the second section of the array 0 Quote Link to comment Share on other sites More sharing options...
