jteerman Posted January 14, 2010 Share Posted January 14, 2010 I'd like to modify my header.tpl file to modify the <title> and <meta description> tags based on the page they are accessing. I've added this to my file: {php} if ( $_SERVER["PHP_SELF"] = "/index.php" ) { $metatitle = "Home Page "; $metadescription = "This is the HOME meta description. "; } if ( $_SERVER["PHP_SELF"] = "/hosting.php" ) { $metatitle = "Hosting Plans Page"; $metadescription = "This is the HOMSTING PLANS meta description. "; } {/php} <title>{$companyname} - {$metatitle}</title> When the page displays, only the company name appears. Any help will be greatly appreciated! Jeff 0 Quote Link to comment Share on other sites More sharing options...
m00 Posted January 14, 2010 Share Posted January 14, 2010 (edited) You can request them inside in a new PHP-tag: {php} if ( $_SERVER["PHP_SELF"] == "/index.php" ) { $metatitle = "Home Page "; $metadescription = "This is the HOME meta description. "; } if ( $_SERVER["PHP_SELF"] == "/hosting.php" ) { $metatitle = "Hosting Plans Page"; $metadescription = "This is the HOMSTING PLANS meta description. "; } {/php} <title>{$companyname} - {php}echo $metatitle;{/php}</title> Edited January 14, 2010 by m00 0 Quote Link to comment Share on other sites More sharing options...
sparky Posted January 14, 2010 Share Posted January 14, 2010 {if $filename=="index"} {assign var="metatitle" value="Home Page "} {assign var="metadescription" value="This is the HOME meta description. "} {elseif $filename=="hosting"} {assign var="metatitle" value="Hosting Plans Page"} {assign var="metadescription" value="This is the HOMSTING PLANS meta description. "} {/if} <title>{$companyname} - {$metatitle}</title> <meta name="description" content="{$metadescription}"> 0 Quote Link to comment Share on other sites More sharing options...
jteerman Posted January 14, 2010 Author Share Posted January 14, 2010 {if $filename=="index"} {assign var="metatitle" value="Home Page "} {assign var="metadescription" value="This is the HOME meta description. "} {elseif $filename=="hosting"} {assign var="metatitle" value="Hosting Plans Page"} {assign var="metadescription" value="This is the HOMSTING PLANS meta description. "} {/if} <title>{$companyname} - {$metatitle}</title> <meta name="description" content="{$metadescription}"> Thanks Sparky! Jeff 0 Quote Link to comment Share on other sites More sharing options...
