UTF-8 MySQL and PDF invoice problem SOLVED
pera
From one version to another I have had problems with utf8, utf8_general_ci, latin1_swedish_ci, etc. etc.
I converted my database to utf-8.
Maybe this will help someone:
1. in control panel / General Settings / Localisation / System Charset
UTF-8
2. In the configuration.php
$mysql_charset = "utf8";
3. This one is tricky. You have to go to phpmyadmin. Then look in every table!
The table can be utf8_general_ci but if you look at table structure and field, there I found some field with latin1_swedish_ci
changing them to utf8_general_ci solved my problem.
and for utf8 in pdf invoice you need to download:
http://www.whmcs.com/members/dl.php?type=d&id=37
more information with pictures:
http://winstart.com/template/section-blog/57-whmcs/250-whmsc-utf-8-solution-guide.html
hope this help someone!
