Changing Assigned Products - Configurable Options
kmm2908
Below is the manual direction for changing the assigned products in a configurable options group. However, I cannot see where to change the assigned products. I can view them but how do I change them? Highlighting them in the list and deleting does nothing; how do I add or delete from this list?
"Managing Options
1. Go to Setup > Configurable Options and click the edit icon next to the option group you want to modify
2. At the top of the page you can edit the name, description and assigned products "
Thanks
