Problem with domain checker
WHMCS version 4.1.1
Bug 1
If you visit your Demo or any WHMCS install (http://demo.whmcs.com/domainchecker.php)
You will see the error.
For the lookup enter "google" and tick all the extensions especially .org
They will all return as unavailable. If you click on the WHOIS info for the .org
Nothing appears - No information.
Bug 2
Still within your domainchecker.php file (http://demo.whmcs.com/domainchecker.php)
Enter a complete heap of rubbish, I used "fsfasdasda" for the lookup, make sure all extensions are ticked, especially the .org
No matter what you type the .org is always unavailable.
I have tested these bugs on several websites and all do the same as above.
https://www.businesshostingonline.co.uk/client/domainchecker.php
http://www.myothello.net/domainchecker.php
https://tshosting.com.au/domainchecker.php
Any help is appreciated
