vePortal Posted October 12, 2009 Share Posted October 12, 2009 Hi all, I've just finished developing this theme for my WHMCS: https://clients.veportal.com This is perfect and how i want it, but as soon as you click "Order" and it goes to "cart.php" (Order) its asif it loads a whole new CSS file? or something in there is causing it to incur major problems that i cannot explain, from what i can find the entire site is perfect other than this one file. Any help apreciated! 0 Quote Link to comment Share on other sites More sharing options...
osckar Posted October 12, 2009 Share Posted October 12, 2009 Hi all,I've just finished developing this theme for my WHMCS: https://clients.veportal.com This is perfect and how i want it, but as soon as you click "Order" and it goes to "cart.php" (Order) its asif it loads a whole new CSS file? or something in there is causing it to incur major problems that i cannot explain, from what i can find the entire site is perfect other than this one file. Any help apreciated! Your SSL certificate shows as not valid 0 Quote Link to comment Share on other sites More sharing options...
vePortal Posted October 12, 2009 Author Share Posted October 12, 2009 Yeah we have just configured global load balancing & GeoIP Location so the SSL certificates havnt been installed/configured on our other servers yet. 0 Quote Link to comment Share on other sites More sharing options...
vePortal Posted October 12, 2009 Author Share Posted October 12, 2009 Style problem fixed by the way it was something todo with "Web 2.0 Cart" i swapped to the older "Cart" and it works perfectly fine now Thanks anyway. 0 Quote Link to comment Share on other sites More sharing options...
