bandr Posted October 1, 2009 Share Posted October 1, 2009 Hey after download whmcs and i did every thing in the Installation Instructions ioncube still not loaded i get this error Warning: dl() [function.dl]: Temporary module name should contain only filename in /home/grandha/public_html/ioncube/ioncube-loader-helper.php on line 411 i set the path correct and upload the ioncube to www folder any feed in this issue ? 0 Quote Link to comment Share on other sites More sharing options...
mylove4life Posted October 1, 2009 Share Posted October 1, 2009 is it your own server? 0 Quote Link to comment Share on other sites More sharing options...
bandr Posted October 1, 2009 Author Share Posted October 1, 2009 yes my server 0 Quote Link to comment Share on other sites More sharing options...
bandr Posted October 1, 2009 Author Share Posted October 1, 2009 the thing i did first thing activate ionecube through Tweak setting and i get this code Main >> Server Configuration >> Tweak Settings Tweak Settings have been updated Your changes have been saved. Restarting cPanel daemons ... Done Updating your system to reflect any changes ... Updating "phploader" from "none" to "ioncube". Using php Loader: IonCubeLoader Installing IonCubeLoader Determining PHP version Installing IonCube Loader binaries Activating IonCube Loader extension in /usr/local/cpanel/3rdparty/etc/php.ini IonCube Loader extension activated "phploader" was updated. Done. then i edit the php.ini adding the following zend_extension = /usr/local/cpanel/3rdparty/etc/ioncube/ioncube_loader_lin_5.2.so then i restart Apache* 0 Quote Link to comment Share on other sites More sharing options...
bandr Posted October 1, 2009 Author Share Posted October 1, 2009 when i try to restart appache in shell command i get this error root@server [~]# apachectl -k restart [Wed Sep 30 21:19:36 2009] [error] VirtualHost *serverip* -- mixing * ports and non-* por ts with a NameVirtualHost address is not supported, proceeding with undefined results root@server [~]# /etc/rc.d/init.d/httpd restat note : *ipserver* = shown the server ip and the server domain is not updated yet cause name.com take time to update the nameserver although i setup another domain in the server register with godaddy and it's working fine i try to setup the whmcs via account ip 0 Quote Link to comment Share on other sites More sharing options...
