Problem with API function addorder to add a domain order
ipaddress
I´m just adding a new order and I have a problem when I want to add a domain order. I´ve tried to put the product id and I´ve tried without it. And in both cases I had the next message with var_dump($results):
array(1) { ["Invalid TLD/Registration Period Supplied for Domain Registration"]=> NULL }
Can you give me an example that shows me how to add a domain order?
Thank you so much!!!
Edited by ipaddress
  • 5 weeks later...
you need to set the values of registration domain in setup / domain pricing
