Problem with ResellOne module
Anatoliy
I have two domains registered with ResellOne. One of them is registered with my WHMCS installation and another with ResellOne web interface. I have added manually the second domain to WHMCS and selected Resellone as Registrar. But when I try to modify this domain I have the next error from Resellone module:
[b]Registrar Error[/b]
Authentication Error.
There is no errors with the fist domain (registered from WHMCS)
How can I add already registered with Resellone domains to WHMCS?
  • 5 weeks later...
I tried to search around for it as well and could not find it either.
Anyway, there's no author information on this file, and I don't claim to be the one to have written it or to provide support for it. If this is your code please chime in and let us know.
So anyway you drop this code into your admin modules and then go to Utilities -> Addon modules and follow the instructions from there.
A little tedious if you have alot of domains to convert, but once you set them up the rest of the registrar functions do work perfectly.
OpenSRS_login_converter.zip
  • 5 months later...
Thanks for info, so it works for someone.. yesterday I tried with it but there is problem modifying username for some domains.. eg. when domain contains dot or dash it cannot be used as username in Resellone system. Has someone idea how these domains are treated?
Thanks
