need help urgently about cPanel login for clients
thehost5968
Hi
I have just inported all the domain from within my WHM and that when very well and smooth but now I can not get to add or change any of the passwords from within the admin or the clientarea.
all i get is:
from the client area is the new password showing(also the password shows as words and not star's as I would like) but when i use the login button it does not work "Login Attempt Failed!"
from the admin I get:
Module Command Error
Sorry, the password you selected cannot be used because it is too weak and would be too easy to crack. Please select a password with strength rating of 50 or higher.
but I have the set to 40 and I now the P/W is higher then 40.
