C Powell Posted July 16, 2009 Share Posted July 16, 2009 I have set it up and all looks good apart from when getting account email for a test setup i did it comes through like jungledj, This message is to confirm the creation of your streaming server account with CentovaCast Streaming Radio Site. Your account information is as follows: Username: jungledj Password: mp4K50kJdH IP address: 127.0.0.1 Port: 8000 Sincerely, CentovaCast Streaming Radio Site Notice the IP address: 127.0.0.1 Any idea where that is coming from? As far as i know i have put the correct Hostname and IP address to use in the Account Template section in CentovaCast as well as put the correct IP address in Add Server section in WHMCS The account works with 127.0.0.1 but you cannot tune into the stream. When i change 127.0.0.1 to the actual IP address of my server it works 0 Quote Link to comment Share on other sites More sharing options...
C Powell Posted July 16, 2009 Author Share Posted July 16, 2009 Just to confirm here Name: Set this to the hostname of the machine on which Centova Cast is running. It has Name in WHMCS but that is just for what you want the server name to be called So shouldn't it actually be Hostname: Set this to the hostname of the machine on which Centova Cast is running. ? 0 Quote Link to comment Share on other sites More sharing options...
C Powell Posted July 16, 2009 Author Share Posted July 16, 2009 when i login to the account and goto Configure Server it has Hostname: 208.116.25.82 IP address: 127.0.0.1 0 Quote Link to comment Share on other sites More sharing options...
holographic Posted August 23, 2009 Share Posted August 23, 2009 Does anyone have a solution for this? I get the exact same error (ip 127.0.0.1). Am I missing a step? Alan 0 Quote Link to comment Share on other sites More sharing options...
C Powell Posted August 28, 2009 Author Share Posted August 28, 2009 You can change it at configuration >> Settings >> Defaults >> Default IP address for new servers 0 Quote Link to comment Share on other sites More sharing options...
