Attachment problem
BWS
Hi all
My clients are not able to upload any type of attachments , upload is success but when i open the attached file it shows ' blank ' , What you think reason from ?
I have submit ticket to WHMCS staff said upgrade your version to latest version
am sure there is alternate solution , please share with me your experience with this
The staff doesnt keep old copies around to fix, which is why they release patches, etc. I got this fixed by upgrading to 4.0.1.
Can i have your WHMCS url pls
The problem is i will lost all modifications which i have done in current version
You only need to replace the following template files:
The following template files have changed from the previous release V3.8
* bulkdomainchecker.tpl
* bulkdomaintransfer.tpl
* clientareaaddcontact.tpl
* clientareachangepw.tpl
* clientareachangesq.tpl
* clientareacontacts.tpl
* clientareacreditcard.tpl
* clientareadetails.tpl
* clientareadomaindetails.tpl
* clientareadomainrenew.tpl
* clientareadomains.tpl
* clientareahome.tpl
* clientareainvoices.tpl
* clientareaproducts.tpl
* clientareaproductdetails.tpl
* clientregister.tpl
* domainchecker.tpl
* downloads.tpl
* knowledgebase.tpl
* passwordreminder.tpl
* supportticketsubmit-steptwo.tpl
* upgrade.tpl
* upgradesummary.tpl
* viewinvoice.tpl
* viewticket.tpl
* All Order Form Templates
Delete all of the files in v4 EXCEPT the ones above and upload. Then you only have a few to change.
My attachments are coming through now. It was my test that wasn't yielding true results - use a fresh image each time you send a fresh email, and with my attachments, chmod to 777, behind the public html directory, and the configuration file set correctly. It works like a charm. :)
