Nerdster Posted June 30, 2009 Share Posted June 30, 2009 (edited) Hello all, Thanks you for taking the time to check this out, Your assistance is appreciated. I am at the final stages of completing my site, I have it live and just tweaking some design and code issues on my short list. One of things on my short list is cleaning up my WHMCS / products and services categories display. I can not find a way to redesign this nicely. I have attached a image of the way it looks at the present moment. Is there anybody that has successfully been able to style this in a better way? I would like to see some sample if possible. Edited June 30, 2009 by Nerdster 0 Quote Link to comment Share on other sites More sharing options...
jaygreentree Posted June 30, 2009 Share Posted June 30, 2009 I would probably use a list my self <ul> <li> Link here </li> <li> Link here </li> <li> Link here </li> <li> Link here </li> </ul> then you could use some css to style it, but thats just my opinion 0 Quote Link to comment Share on other sites More sharing options...
Nerdster Posted June 30, 2009 Author Share Posted June 30, 2009 Hi jayGreenTree, Thanks for your reply. I would also use list myself, but from what I have found so far, (and I may be wrong) is this section is encoded? 0 Quote Link to comment Share on other sites More sharing options...
jaygreentree Posted June 30, 2009 Share Posted June 30, 2009 It should be in one of the .tpl files but off the top of my head I don't remember which one 0 Quote Link to comment Share on other sites More sharing options...
