ThELasTSamuRaI Posted June 10, 2009 Share Posted June 10, 2009 Hi i just installed whmcs and im configuring it right now but it seems the is a problem with domains checker and domains registration (there is no TLD) u can see here http://www.tnhoster.com/whmcs/cart.php?a=add&domain=register  i have installed all the TLD in pricing and putted my resellerclub ID  any help will be appreciated Thanks 0 Quote Link to comment Share on other sites More sharing options...
chickendippers Posted June 11, 2009 Share Posted June 11, 2009 Hi, That looks like you haven't set the pricing correctly. 0 Quote Link to comment Share on other sites More sharing options...
ThELasTSamuRaI Posted June 11, 2009 Author Share Posted June 11, 2009 Hi,That looks like you haven't set the pricing correctly. Â thank you for ur answer it seems that this was the problem and i have fixed any idea on how to delete the US$ currency? thanks in advance 0 Quote Link to comment Share on other sites More sharing options...
chickendippers Posted June 12, 2009 Share Posted June 12, 2009 Setup > Currencies > click the red and white x. 0 Quote Link to comment Share on other sites More sharing options...
ThELasTSamuRaI Posted June 12, 2009 Author Share Posted June 12, 2009 Setup > Currencies > click the red and white x. Â the problem is that there is not an X in front of us $ 0 Quote Link to comment Share on other sites More sharing options...
bubbasheeko Posted June 12, 2009 Share Posted June 12, 2009 (edited) Why not replace US and edit it the notepad with the pencil (on the right) - change it to what ever currency you want to use. That will be your default currency then add other currencies you want to be able to convert to. Â I noticed that your currency doesn't update either - If I choose between DT and USD the price remains at $5.00. Â Make sure this is checked: Â Update Pricing Tick to recalculate prices for this currency using the conversion rate Edited June 12, 2009 by bubbasheeko 0 Quote Link to comment Share on other sites More sharing options...
chickendippers Posted June 13, 2009 Share Posted June 13, 2009 Yes, as bubba has said, you will just need to edit the default currency. 0 Quote Link to comment Share on other sites More sharing options...
