Problems with currency
pdthosts
Hi guys,
I'm in need of some help. I have set my WHMCS up to use the GBP as the default and ONLY currency. When customers place orders on the site Google Checkout kicks out an error, when I go into the integration console I get this error back from Google;
<?xml version="1.0" encoding="UTF-8"?>
<error xmlns="http://checkout.google.com/schema/2" serial-number="819f24c7-6d98-4713-92af-dd37c5b5ec76">
 <error-message>Error parsing XML; message from parser is: Invalid value for attribute currency in checkout-shopping-cart/shopping-cart/items/item/unit-price: </error-message>
</error>
The code WHMCS is sending is;
<checkout-shopping-cart xmlns="http://checkout.google.com/schema/2">
 <shopping-cart>
   <items>
     <item>
       <item-name>PDT Hosts</item-name>
       <item-description>Invoice #1000012</item-description>
       <unit-price currency="">8.00</unit-price>
       <quantity>1</quantity>
     </item>
   </items>
   <merchant-private-data>1000012</merchant-private-data>
 </shopping-cart>
 <checkout-flow-support>
   <merchant-checkout-flow-support>
     <edit-cart-url>https://www.pdthosts.com/billing/viewinvoice.php?id=1000012</edit-cart-url>
     <continue-shopping-url>https://www.pdthosts.com/billing/viewinvoice.php?id=1000012</continue-shopping-url>
   </merchant-checkout-flow-support>
 </checkout-flow-support>
</checkout-shopping-cart>
This clearly shows that no currency is going through to Google however I can see no problems with my set-up of my products, currency or payment gateways.
The problem first occured when I deleted the USD currency and overwrote it with the GBP.
Thank You
Andrew @ PDT Hosts
