I Need help integrating iDevAffiliate
Does anyone have any information on how to get iDevAffiliate integrated with WHMCS?
I do like the current affiliate whmcs feature but it has some features that i don't really understand how to fix.
For example having to go through each new affiliate and setting them as fixed amount etc.. I just cant do that.
  • 3 weeks later...
  • 1 month later...
This how you may integrate iDevaffiliate: http://wiki.whmcs.com/Action_Hooks
So far I understood, the InvoicePaid has to be used to integrate iDevAffiliate. Thus, upon payment receipt, will be the order validated and sent to iDevAffiliate for commission. However, the new problem is to integrate the multi-currency scheme and so far, I have no idea how it could work...
Hope this help.
  • 4 weeks later...
  • 4 weeks later...
You should upgrade to iDevAffiliate version 6.02 for both security and new features. The newest version has an integration wizard for several carts and billing systems, WHMCS being one of the built in ones, so it gives you the code and tells you where to place it.
