Help Setting-up ENOM
Beau
I'm having the same trouble that cocabean had:
1) I have set up enom in the configuration settings under domain registrar, 2) Entered my username and password,
3) Setup the cron job for expiry status,
4) Entered my default name servers, and
5) Setup Domain Prices (set as Open Pricing)
I also have cURL support enabled:
cURL Information libcurl/7.19.4 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5
I am receiving no errors, but nothing happens when I search for a domain, and no extensions are appearing in the dropdown for .com/.co.uk etc.
I opened a ticket with WHMCS, but no answer yet. Can anyone point me in the right direction?
Thank you!
What do you mean by "set as open pricing" in step 5?
No tlds in the dropdown is caused by pricing not being set.
http://wiki.whmcs.com/Enom
You'll also need to contact eNom and have them add your IP to the whitelist.
DOH! Just found the pricing LINKS. This should maybe be made a bit more OBVIOUS in the UI! Goodness ...
