Default Cart Currency Problem
jissh
Our cart option is "default", when placing a order and changing the currency from other then the default assigned we receive the following error.
The requested URL https://www.urlremoved/clients/cart.ph was not found on this server.
As you can see there is a error in the cart.php extension. All the other cart templates are fine accept for the default. Can anyone else reproduce this problem.
Found the problem. Just need to open products.tpl in the default order template and replace <form method="post" action="cart.ph?gid={$smarty.get.gid}p"> with <form method="post" action="cart.php?gid={$smarty.get.gid}">
