kvchosting Posted April 23, 2009 Share Posted April 23, 2009 I have applied cdgcommerce & quantum gateway. I have setup everyting on WHMCS admin, put the user, the restriction key. EVEN the quantumgateway cs help me look at it and make sure everything ok. THE PROBLEM IS 1. when i paid my invoice even 0.01 cents it does not return anything for me , once i click paid just run then go back to ticket page and still showing unpaid, even i click 3d check out 2. why we have that 3d checkout button anyway, can you guys remove it for me? that 3d check out button connect to the merchant 3. even i ask merchant peopel to look at it, it said i need contact you guys whmcs it something in whmcs is not connecting to their gateway/merchant. they said its not verifying does anyone know what happen i did put correct restriction key and username 0 Quote Link to comment Share on other sites More sharing options...
tweaked Posted April 24, 2009 Share Posted April 24, 2009 Open a support ticket with WHMCS, Matt and crew have very good support. 0 Quote Link to comment Share on other sites More sharing options...
