johnh Posted January 5, 2007 Share Posted January 5, 2007 Hi, When I tried to add new article on knowledgebase and it went fine, but when I tried to click right-click and select insert/edit link or like that on text, it opened small window, but it did not show any content or setting box so on.. please check it thanks 0 Quote Link to comment Share on other sites More sharing options...
WHMCS CEO Matt Posted January 6, 2007 WHMCS CEO Share Posted January 6, 2007 I have checked and this is working fine. Check you have uploaded all the files in admin/editor/ 0 Quote Link to comment Share on other sites More sharing options...
johnh Posted January 6, 2007 Author Share Posted January 6, 2007 it was on ver3 beta1.. let me check again..new window was showing like {} part on title.. thanks 0 Quote Link to comment Share on other sites More sharing options...
johnh Posted January 6, 2007 Author Share Posted January 6, 2007 checked again.. it was still same..new window says on title {$lang_insert_link_title) with empty window and could not even click right click on that window.. also url was https://my.ihubnet.com/admin/editor/themes/advanced/link.htm it was same on beta1 and beta2.. hm.. thanks 0 Quote Link to comment Share on other sites More sharing options...
WHMCS CEO Matt Posted January 6, 2007 WHMCS CEO Share Posted January 6, 2007 Sounds like this might be an issue with the FCKeditor and your language. 0 Quote Link to comment Share on other sites More sharing options...
johnh Posted January 7, 2007 Author Share Posted January 7, 2007 okay.. I am going to test it on firefox.. and let you know.. also language is set as English on my windows...hm. 0 Quote Link to comment Share on other sites More sharing options...
johnh Posted January 7, 2007 Author Share Posted January 7, 2007 I think it was browser issue..checked on firefox and worked fine, but not on IE7. 0 Quote Link to comment Share on other sites More sharing options...
WHMCS CEO Matt Posted January 7, 2007 WHMCS CEO Share Posted January 7, 2007 Ok, I don't think FCKEditor fully supports IE7 yet. I'll look into it. 0 Quote Link to comment Share on other sites More sharing options...
bedot Posted January 7, 2007 Share Posted January 7, 2007 im using IE7 as my primary browser, all features work for me. 0 Quote Link to comment Share on other sites More sharing options...
