HarryB Posted April 5, 2009 Share Posted April 5, 2009 Hi, I have just finished my site, and now when I order with WHMCS, it is all fine untill it gets to the checkout. It shows http://www.mydomain.com/billing/cart.php?a=checkout as completely blank. Any one able to shed any light on it? Cheers 0 Quote Link to comment Share on other sites More sharing options...
chickendippers Posted April 5, 2009 Share Posted April 5, 2009 You most likely have a template error. If you re-upload the default template the problem will go away. 0 Quote Link to comment Share on other sites More sharing options...
HarryB Posted April 5, 2009 Author Share Posted April 5, 2009 Cheers. Seems to happen with all templates but will try that 0 Quote Link to comment Share on other sites More sharing options...
HarryB Posted April 5, 2009 Author Share Posted April 5, 2009 Tried that to no avail :'( 0 Quote Link to comment Share on other sites More sharing options...
HarryB Posted April 8, 2009 Author Share Posted April 8, 2009 Sorted with help from the WHMCS support team. Was a php.ini issue with PHP memory or something like that 0 Quote Link to comment Share on other sites More sharing options...
