Knowledge base problems
attroll
I have had problems trying to type in a large description in my knowledge base. Is there a limit to how many characters you can type in my knowledge base? I can add small writeups, but when I try to post a large on I get the following error.
Forbidden
You don't have permission to access /whmcs/admin/supportkb.php on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Apache/1.3.37 Server at http://www.whiteblazehosting.net Port 80
if you want to post your article here, im sure one of us could try to add it to our systems to see if smiilar errors occur.
but i would guess its a character like / or " or /"
i did have a specific character set issue with another help desk product, cant remember what it was.
The word "curl" used to be blocked by mod_security on our server and prevented support tickets from being submitted about curl issues. Then people complained our ticket system didn't allow tickets to be submitted! I don't think characters like that are an issue.
Matt
I am trying to post a writeup in about our data center and here is the writeup that is giving me the error:
Located at the edge of downtown Dallas on one of the most fiber rich routes in the city, the fully-equipped, 28,000 square foot facility is staffed around the clock. With uncompromising standards for security, power supply and environmental controls, we focus on connectivity, redundancy and resilience.
Network
Multiple carriers with diverse building entrances
Fully redundant Cisco architecture using 12008 routers and 6509 Layer3 switches
HSRP failover protection
Dual network feeds to each customer
99.5% Service Level Agreement
Power Systems
Leibert and Powerware UPS with 120, 208, 220VAC available
Maintainance by-pass
2400 amps DC plant
100% diesel generator backup with auto start and auto transfer switch
Generator capacity equal to building utility service
A and B DC plants totally diverse
Fuel capacity exceeds 24 hours
Fuel delivery contract with 2-hour guarantee
Environmental Controls
Constant ambient air temperature of 68° (+ or - 2°)
Liebert air
Under-floor cooling
Humidity control via Liebert units
Security and Access
Biometric Scanner
24x7 on-site technicians
Multiple layers of 24x7 security cameras, card readers, and key pads
Access to equipment area 24x7 via card key and key pads
Non-customers enter equipment area by escort only
All cabinets, cages, and suites are locking, with security upgrades available
Facilities are monitored with 24 hour recording and 5 day video storage
Fire Suppression Systems
Pre-action sprinkler rated for telecommunication equipment and computer room
Integrated smoke/heat detector system
After reading all the replies I went back and started playing with some things. I found out that there was a word that was causing this error. It was the word "plant". Do not ask me why this does it but if I remove the word plant from the writeup then I can get it to save.
Is there a setting someplace on my server or in WHMCS that is causing this word to do this?
