Problems with ENOMSSL module
Jacksun
I may be the only one having this issue. I set up the ENOM SSL certificates in WHMCS, following the documentation and all.
When I put the link into my web page, if you select say 2 years, when you click the buy now button and it takes you to the cart to checkout, it only shows the 1 year price. Even if I remove the term selection on my web page (might just be my html form coding issue) you also cannot change the certificate term on the cart page to buy more years.
Does anyone know how to set up the enomssl module so you can choose your certificate term on the cart page? Or does this need to be done on my web page?
If you are only buying one year it seems to work well :0)
thanks,
Wayne
