crombiecrunch Posted February 27, 2009 Share Posted February 27, 2009 Hello all I am looking to get some help with a site integration. I have everything pretty much setup but I am running in to a few problems. All the following problems happen in my new integration only. I have a older integration on the server and I do NOT have these issues. WHMCS ver 3.8.1 1. When using the domain check feature, no matter what domain name you enter and hit submit, it comes back that that domain name is available for purchase. This does this from both the code on the site template and from within WHMCS itself. 2. When logging in to the client area it just opens up a blank page but does log you in if you hit the back button. 3. While in the admin area and browsing through the clients, when you click on the domain tab to see if they have a domain with us it opens a blank page, all other tabs work fine. I am sure there might be some other issues but I dont really know how to look for/test for it properly. <<removed>> 0 Quote Link to comment Share on other sites More sharing options...
chickendippers Posted February 27, 2009 Share Posted February 27, 2009 3. Try reuploading the admin files. 0 Quote Link to comment Share on other sites More sharing options...
rockman Posted March 1, 2009 Share Posted March 1, 2009 I am having the same problem as number 2 above. My "public" page or billing page is almost blank, only showing "powered by WHMC.." Any help would be awesome. 0 Quote Link to comment Share on other sites More sharing options...
