Custom registrar module issue
jurgonaut
I downloaded the RegistrarDevKit.zip file and am trying to integrate a custom registrar module. At this very time when I try to configure the registrar module trough Configuration => Domain Registrars => Registrar Settings => xyz (listbox) I am redirected to the General Settings tab without any registrar options form being shown.
Here's what I did :
- Took the template.php file.
- renamed it to xyz.php
- modified "template_" to "xyz_" for all functions
- created a directory named "xyz" under /modules/registrars and put all files in it (permissions and owner are correct)
- for testing purposes I even commented out all functions except xyz_getConfigArray()
Trying to debug I also discovered the table "tblregistrars" contains the fields mentioned within the getConfigArray. Adding the needed fields (Username & Password) didn't solve the problem.
What am I doing wrong ? Or what did I omit in order to make the module work ?
Thanks in advance for any pointers provided :)
Edited by jurgonaut
