PlanetDomain WHMCS Module PROBLEMS
toxicdav3
I need some help just cannot get it working! Contacted both PlanetDomain and WHMCS no help at all :(
Domain Registrar Error
Error Code: 411 - Field incorrectly formatted | user.phone ...
You have to have 1 number area code then your phone number. Looks like I have to edit nearly every client's profile because 90% of them don't enter it correctly. Easy fix in the module file or have a minimum number requirement when a client registers!
An Error Occured
Error Code: 412 - Value not unique | user.username
The username is the clients first and last name limited to 15 characters. Turns out a lot of my clients names has already been assigned to other users. I would like to change the username, at least add something to the front of it!
An Error Occured
Error Code: 420 - Operation failed | com.primus.tld.register.RegisterException: completed: NO
Finally just cannot register a domain. Dead end :S
Help please!!! I would at least try and fix this stuff myself but the module file is encrypted.
