cody.lundquist Posted January 7, 2009 Share Posted January 7, 2009 Greetings, Using a test account on my site, I can't add products to my cart to checkout. I select the product I want, then the price then after I click "Add to Cart" it doesn't get added. I just upgraded to the newest version of WHMCS and it did not fix my problem. 0 Quote Link to comment Share on other sites More sharing options...
cody.lundquist Posted January 7, 2009 Author Share Posted January 7, 2009 FIX (apparently I can't edit my original post) I've found a fix for this. To see if you need the fix, create a file in your root direction where whmcs is installed called "sessionpath.php". Inside that file write in: <?php session_start(); echo "Session save path is ", session_save_path(); ?> Go to your browser and execute that file, if it reads: "Session save path is N;/path", this is the fix for you. Create a file called ".htaccess" in the root directory of whmcs (if the file is already that file there then just add the line below) and add the line below: php_value session.save_path '/tmp' Then create a directory called "tmp" and change it's permissions to 777. Done . 0 Quote Link to comment Share on other sites More sharing options...
