josepi Posted December 27, 2008 Share Posted December 27, 2008 The problem is after seleccting the package - My problem is that When someone clicks on the package to add to the cart whmcs/cart.php?a=add&pid=1 , then I have to choose the domain name I write any domain Inside the text box , then click on check availability and then It get stucks loading , never end's but If I go directly to the cart and chose everything from there works ok , just doesn't work adding a product to the cart whmcs/cart.php?a=add&pid=1 0 Quote Link to comment Share on other sites More sharing options...
