Problem with CC Processing
tvgJason
I am attempting to run cards and after the recent upgrade I am unable to.
Things I have found:
When trying to run the card I get:
>> Capture Error
>> An unknown error occurred. Please check the gateway log.
The gateway log is empty.
When trying to pull the CC# directly so that I can run it by hand it asks for the hash. I input the exact hash as noted in the configuration.php file and it says it is invalid.
These are likely related however I need to run cards soon. Any assistance would be fantastic.
I am using Quantum Gateway and I have double checked to see that the login id and restrict key are correct.
Thank you in advance.
